Old 07-10-2016, 11:45 AM   #337
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Thumbs up
Originally Posted by Tap View Post
Friends, today is a beautiful day!!
After over 6 months of sadness, frustration, blood (literally), sweat, tears, a lot of money, and hard work, I'm thrilled to announce that my 280 is finally able to cruise down the highway without a tow truck!
Congrats Tap, I have some of those stains on my driveway and holes in my valet. I can appreciate what you went through to get to this point
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-10-2016, 04:57 PM   #338
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Tap's 1981 280 Motorhome (Purchased January 2016)
Thanks so much guys! Your encouragement and great advice were the only things keeping me from just walking away from my money pit on wheels.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 07-10-2016, 04:58 PM   #339
Tap
Tap's Avatar
But now I hated for this weekend to end!
Name:	ImageUploadedByAirstream Forums1468191483.756910.jpg
Name:	ImageUploadedByAirstream Forums1468191500.077214.jpg
Old 07-10-2016, 05:02 PM   #340
Tap
Tap's Avatar
Ok, now I know this question has been asked a lot, but I couldn't find it in a search.
Name:	ImageUploadedByAirstream Forums1468191753.292860.jpg
1) How do we remove the plastic ceiling light covers to clean out all the bugs and replace the bulbs with cooler and more efficient LED ones?
and then...
2) Which LED bulbs are the right replacements for these?
3) Where should I order them from? Are they on Amazon? That way I could get them in 2 days.
Thanks!
Old 07-10-2016, 10:08 PM   #341
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Tap, blow dryer on low to warm the plastic, gently squeeze and remove, held in opposing channels by tension. I do not recall which bulb, but I have an led in bulk link from amazon for them all if you send me conventional bulb number.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 07-10-2016, 10:31 PM   #342
Tap
Tap's Avatar
Perfect! Thanks buddy!
Old 07-11-2016, 03:48 AM   #343
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Tap, If you happen to need any of those lens just let me know. I changed all mine out to puck lights and saved the lenses. They are yours if you need any.
Mike
mayco is offline   Reply With Quote
Old 07-11-2016, 07:23 AM   #344
Tap
Tap's Avatar
Mike
Perfect, thanks Mike, I'll see how it goes!
Old 07-11-2016, 07:30 AM   #345
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Congrats Tap, your rig looks nice parked lakeside there. Glad that you are starting to get some camping fun with your coach. That should help with keeping you going with the projects.
Cheers Richard
tevake is offline   Reply With Quote
Old 07-11-2016, 10:41 AM   #346
mattpalmeris's Avatar
nanaimo , British Columbia
Blub
Attachment 266405
and then...
Thanks!
I actually have a rig that looks identical to yours and just went through the process of changing the bulbs in the same fixtures.
I used ebay as my source and in those light housing there are two sizes of bulb, both have the same tailpiece and searching eBay for 1156 led bulbs with give you a bunch of options. 1156 is what was stamped on my larger of the two bulbs. For the high setting I went with a 28 led option and low an 11 bulb.
At first I went with a natural light led 3000k because I liked the warm glow of the current bulbs but when I received them they had a green hue to them so I went with 5000k and they are brighter and look better then the 3000's I had. There are different qualities of leds but the ones I received were about $12 for sets of 10.
Your project looks great!
mattpalmeris is offline   Reply With Quote
Old 07-11-2016, 12:54 PM   #347
Tap
Tap's Avatar
Matt, any chance you could provide the link for the 5000K 1156 28 and 11 LED bulbs that you used?
I've been doing the search on there and there are a million of them, and I can't seem to find the ones you mentioned.
Sorry if this is a pain. Thanks!
Old 07-11-2016, 07:34 PM   #348
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Tap
There is some good info on the bulbs I used to replace my isle lights and trunk lights in this tread.. There is a ebay link to bulbs I used in the thread..
http://www.airforums.com/forums/f310...ts-135058.html
I have also bought a couple other bulbs but, the links are old and no longer work.
The bulbs I used for overhead bright lights from Yitamotor are;
10x white 1156 BA15s Le 27-SMD $14.88 Light BulbsTail backup RV Camper bright bulbs interior
These are bright white when illuminated, some folks don't like the bright white but, I like them really well and at a buck and a half each you can't go wrong.
Gregsch is offline   Reply With Quote
Old 07-11-2016, 08:01 PM   #349
Gregsch's Avatar
Tipp City , Ohio
I think these are the overhead bright lights
http://www.ebay.com/itm/201291799753
I think these are the walkway lights
http://www.ebay.com/itm/281743835989
I am going to try these to replace the low lights in the overhead lights
http://www.ebay.com/itm/281801293688
Just ordered all 3. I can let you know how I like them in a week or so if you like.
Old 07-11-2016, 09:02 PM   #350
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
To heck with the lights.........replace them when they die.
You need to give her a present and some bling......
http://www.phoenixusa.com/p-10632-ng961.aspx
Don't forget air extenders as well, which can be purchased on the same site.
The way these are fastened on to the wheel is the best system I have ever seen.
PM me about party size for our meet up, Also remember passports for everyone.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
