Old 06-29-2016, 10:49 PM   #295
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Interesting, it looks from the picture that the mount is welded to the vertical tube welded to the receiver tube. Is it also supported forward of the bumper? Must be fun removing the bumper.
I think I might cut the vertical plate and gussets right at the base horizontal plate. Then move it aft maybe 2" and weld it back on. Also weld a tube frame around the perimeter of the vertical plate, maybe a 1-1/4" square tube. The plate looks thick enough but the tube frame will add a lot to prevent bending. The later type mount on my 280 is actually a bent square tube with a light plate welded across the top where the wheel is bolted on. Just an idea.
Cheers, Dan
~ Margaret Thatcher ~
Old 07-02-2016, 06:42 PM   #296
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Tap's 1981 280 Motorhome (Purchased January 2016)
So I finally have a working automatic step!
The great guy helping me with repairs was able to get the replacement solenoid for under the step, replaced a few vacuum hoses and it now works!
It immediately tucks under when I start up the engine. Interestingly though, when the engine is off, it takes about 10 minutes to extremely slowly and eventually come back out as a step.
But at least it works and it's way better then when it stayed permanently out.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 07-03-2016, 05:49 AM   #297
It sounds like you have a restriction in the exhaust port of the valve. The steps should extend fairly quickly, as in seconds not minutes once the engine is turned off.
bkahler is online now   Reply With Quote
Old 07-03-2016, 09:04 AM   #298
Tap
Tap's Avatar
Thanks so much, I'll look into that. Very helpful!!
Old 07-03-2016, 10:14 AM   #299
Tap
Tap's Avatar
So the metal shelves in my Norcold refrigerator are super rusted. I'd like to replace them with new ones.
Does anyone know if Norcold still sells replacements or if a 3rd party does?
Name:	ImageUploadedByAirstream Forums1467562385.664543.jpg
Name:	ImageUploadedByAirstream Forums1467562442.602556.jpg
Thanks!
Old 07-03-2016, 10:26 AM   #300
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Tap, I cleaned mine up the best I could with a wire wheel and then clear coated them. Not great but not bad. I priced replacements and they were crazy expensive. Its been a while but I think they were wanting $50 a shelf. Not gonna happen.
Mike
mayco is offline   Reply With Quote
Old 07-03-2016, 10:37 AM   #301
Tap
Tap's Avatar
Mike
Thanks Mike, where did you see those replacements? Thanks.
Old 07-03-2016, 02:16 PM   #302
mayco's Avatar
Boy Tap, its been too long I cant remember. I dont think it was on Dometics site though.
Old 07-03-2016, 02:57 PM   #303
Tap
Tap's Avatar
Ok, no prob. I'll do some checking around. Take care buddy!
Old 07-06-2016, 01:56 AM   #304
Tap
Tap's Avatar
My pantry closet just to the right of my refrigerator looks like hell.
All of the shelves are missing and the bare metal erector-set-like rack is exposed.
Name:	ImageUploadedByAirstream Forums1467791654.054129.jpg
Name:	ImageUploadedByAirstream Forums1467791672.268861.jpg
What should it really look like?
I'm going to measure for each of the shelves and cut some plywood to go on each level. But what covered up the metal supports? Some plastic trim or faux wood vinyl shelf paper?
This pantry definitely needs a makeover.
Thanks!
Old 07-06-2016, 07:15 AM   #305
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
We just rented a campervan in New Zealand that had a setup for the dishes that I really liked. A few inches above the bottom of a drawer, a second "false bottom" was installed with cutouts that fit the plates, bowls, and cups. There was actually one cutout that fit all the plates, one that fit all of the bowls, and one for each cup. Just drop them in their slot, and no rattle at all when driving. You might want to think about this for one of your shelves.
Waipio Rim is offline   Reply With Quote
Old 07-06-2016, 06:23 PM   #306
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Waipio Rim, Do you happen to have pics of that setup? Sounds pretty neat!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 07-06-2016, 08:51 PM   #307
Tap
Tap's Avatar
Cool idea Waipio Rim.
Anyone have a pantry closet just like mine, but looking nice, who could take a photo so I could see how the bones are covered?
Thanks!
Old 07-06-2016, 09:07 PM   #308
Vycan's Avatar
Manhattan , Kansas
Tap,
I do not, mine is done totally differently. Sorry brother.
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
