Old 06-20-2016, 08:06 PM   #267
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just to add the AGM Optima deep cell batteries have a blue top and are meant for RV/Marine use. The red top is exclusively auto start and the Yellow is a hybrid, so a mix of two blue and one yellow would be the best combo.
If price is of concern, having two wet cell deep cycle batteries for coach is just fine.
Glad to be of help Mark, keep the questions coming.
Cheers
Tony
Old 06-23-2016, 01:57 PM   #268
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Hey guys, do you know where I should get a replacement for this Cain pump for under my step?
Name:	ImageUploadedByAirstream Forums1466711826.070657.jpg
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 06-23-2016, 05:57 PM   #269
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Originally Posted by martin300662 View Post
I got all the screws out this afternoon Tap, but someone has been a little over zealous with the Vulkem on the corners where they meet the inner skins. If get it out when I go over to AS NE tomorrow. PM me you address and I will drop it in the mail to you.
Can't help with your pump Tap but the step is out (along with a light and the switch).
PM me your address and I will get it on the mail to you.
martin300662 is online now   Reply With Quote
Old 06-23-2016, 10:31 PM   #270
Tap
Tap's Avatar
Thanks Martin!
I'll PM you now!
Old 06-24-2016, 01:07 AM   #271
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Attachment 265017
Mark I believe that is a solenoid that allows engine vacuum to pull in the step when the door is closed. The switch in the door jamb energizes the solenoid which allows vacuum to the diaphragm in the actuator to the rear to pull the steps in. With the engine off or the solenoid closed, springs extend the steps and keep them out. By the way if you need the actuator it is the headlight actuator from a '68 to '82 Corvette. I'm not sure if the solenoid is generic or a specialized part.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-24-2016, 07:32 AM   #272
Tap
Tap's Avatar
Thanks Smartstream! That helps a lot!
Oh and I had typed, "vacuum pump", but somehow the autocorrect on my phone changed it to, "Cain pump". Hehe!
Thanks again!
Old 06-24-2016, 08:06 AM   #273
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Hey Tap,
Did you get that video I tried to send? Im not very confident in my computer abilities. It seemed like it sent ok.
Mike
mayco is offline   Reply With Quote
Old 06-24-2016, 11:11 PM   #274
Tap
Tap's Avatar
Tap's 1981 280 Motorhome (Purchased January 2016)
Originally Posted by mayco View Post
Hey Tap,
Mike
I did, thank you SO much Mike!
I thought I wrote you back, I must not have.
I love the video because it captures the long lines of classic motorhomes.
I really appreciate it buddy!
Old 06-25-2016, 12:24 PM   #275
Tap
Tap's Avatar
Friends, can anyone tell me where to get a proper replacement for the solenoid that controls my automatic vacuum powered step? Mine is shot and I need to get one as soon as I can. Thanks!!
Name:	ImageUploadedByAirstream Forums1466879037.302765.jpg
Old 06-25-2016, 12:34 PM   #276
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Attachment 265174
This thread maybe helpful Tap....particularly post #5 has part numbers of alternate parts.
Apparently it is sold as a fuel selection valve.
Old 06-25-2016, 12:38 PM   #277
Tap
Tap's Avatar
Thanks Martin, that's great!
I think you forgot to attach the live link to the thread though.
Old 06-25-2016, 02:10 PM   #278
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Sorry Tap.....let me try again! http://www.airforums.com/forums/f311...lay-49351.html
Old 06-25-2016, 02:19 PM   #279
Tap
Tap's Avatar
Thanks man!!
Old 06-25-2016, 02:26 PM   #280
Tap
Tap's Avatar
Hey Martin, click on that link.
I think it goes to a whole different topic.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
