Old 01-24-2016, 11:43 AM   #15
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Name:	ImageUploadedByAirstream Forums1453660798.180640.jpg
ID:	256204Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660816.300194.jpg
ID:	256205Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660837.735571.jpg
ID:	256206Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660867.753578.jpg
ID:	256207Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660886.292377.jpg
ID:	256208Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660930.727765.jpg
ID:	256209Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660947.098298.jpg
ID:	256210Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660975.052571.jpg
ID:	256211Click image for larger version
Name:	ImageUploadedByAirstream Forums1453660994.720132.jpg
ID:	256212Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661007.038216.jpg
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 01-24-2016, 11:48 AM   #16
Tap
Tap's Avatar
Name:	ImageUploadedByAirstream Forums1453661078.364693.jpg
Name:	ImageUploadedByAirstream Forums1453661113.268387.jpg
ID:	256215Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661126.570476.jpg
ID:	256216Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661140.888675.jpg
ID:	256217Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661155.972892.jpg
ID:	256218Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661182.379444.jpg
ID:	256219Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661199.647522.jpg
ID:	256220Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661214.612642.jpg
ID:	256221Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661234.133729.jpg
ID:	256222Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661254.950018.jpg
ID:	256223Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661285.805295.jpg
Old 01-24-2016, 11:52 AM   #17
Tap
Tap's Avatar
Name:	ImageUploadedByAirstream Forums1453661317.543833.jpg
ID:	256225Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661334.828142.jpg
ID:	256226Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661370.616364.jpg
ID:	256227Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661394.952604.jpg
ID:	256229Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661442.825346.jpg
ID:	256230Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661454.228350.jpg
ID:	256231Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661476.029574.jpg
ID:	256232Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661498.647493.jpg
ID:	256233Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661530.885041.jpg
Old 01-24-2016, 11:55 AM   #18
Tap
Tap's Avatar
Name:	ImageUploadedByAirstream Forums1453661582.307465.jpg
ID:	256236Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661598.341834.jpg
ID:	256237Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661620.079526.jpg
ID:	256238Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661661.091879.jpg
ID:	256239Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661684.028359.jpg
ID:	256240Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661705.080790.jpg
ID:	256241Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661742.319461.jpg
ID:	256242Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661753.904445.jpg
Old 01-24-2016, 11:58 AM   #19
Tap
Tap's Avatar
Name:	ImageUploadedByAirstream Forums1453661803.677126.jpg
ID:	256244Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661824.930433.jpg
ID:	256245Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661866.520548.jpg
ID:	256246Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661879.937366.jpg
ID:	256247Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661899.341271.jpg
ID:	256248Click image for larger version
Name:	ImageUploadedByAirstream Forums1453661924.642678.jpg
Old 01-24-2016, 11:59 AM   #20
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Our 310 tends to sit for long stretches. The last time I went to start it, the starter engaged but would not turn the motor over on the first try. On the second try and for the rest of the trip, it started. I got the feeling that the rings were probably stuck to the cylinder walls on that first try. You might want to see if the motor can be turned over by hand if you can get a socket on the crank pulley bolt.
Waipio Rim is offline   Reply With Quote
Old 01-24-2016, 12:20 PM   #21
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Sorry , you couldn't get her home, but thanks for sharing your enthusiasm!
The body looks very straight, it may have some frame rust, but hopefully it was stored under cover for a long time.
First thing I would do is get the radio and the heater working and then go on a wildlife hunt. You may have some critter infestation that can be very destructive.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-24-2016, 12:32 PM   #22
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Welcome aboard Tap. Sorry the hear the first day did not go as planned. Be forewarned 90% of my projects have taken longer and been more involved than I originally thought. As for what my wife calls the money pit, well ... we won't go into that.
Gregsch is offline   Reply With Quote
Old 01-24-2016, 02:00 PM   #23
Yup, these things happen.
A few thoughts based on the pics and comments.
When looking for chassis parts, remember that is a a 1981 P30 first, with a 7.4 Big Block, and then a Motorhome chassis. You will find that will get you on the right parts page and allow the parts guy to locate what you need.
The transmission is normally a TH475, which is a slightly HD version of the TH400, but with straight cut sun gear and a parking drum brake on the back.
Brakes should be "JF9", which is to say Hydroboost operated, discs on all wheels. The rotors on the front are slightly larger than the rear, but they use the same caliper and same pads... and none of that is expensive to replace.
RockAuto is a great source of parts at good prices, but sometimes you local autoparts place can come close, and its either right there on the shelf, or 24hrs away.
If I were you, here would be my priority list when it arrives "Home".
1/ Get her watertight if she will be living outside. That means sealing over the broken and missing glass obviously for starters. Then I would pull up/inspect all the floors looking for staining or wet ply/OSB. This will tell you what the story is or was. Here are the favorites leaks places. A/ windshield/cockpit side windows. B/ Joints on front and rear end caps. C/ Roof piercings, like AC Units, Fan units, and my fave, the seals on the grey and black tank roof vents.
2/ Find used glass for the cockpit and side windows that are missing. Windshield glasses and seals, will be new I assume.
3/ Go thru the Motor/Trans/Cooling/Fuel/Brakes/axle replacing all fluids/filters/rubber hoses, unless you have evidence of more recent work. As you go, look for leaks and other clues from the past. If I was dropping the trans pan, I would never replace the stock tin pan and would go with a deep aluminum or Derale steel pan($120) with a drain plug and magnets... altho this will probably involve a little trans Xmember clearance...
4/ New tires... manly people have swapped from the original 8R 19.5 to 225/70R 19.5 without issues.
5/ Replace the broken Headlamp units with HID 4x6 conversion kits($85), that will be totally brighter AND remove the electrical load from the notoriously weak GM headlamp switch/wiring.
That should keep you busy for a couple of weeks....
Old 01-24-2016, 02:09 PM   #24
You added some more pics while I was writing my last post...
Awesome!
Gives us some more clues.
Yes, I agree with Peter.... some critter hunts would be VERY wise... maybe Peter will break out his Pipe(Being from Hamlet)... sorry Peter, I had to say it!
Looks like you might need some AC work!
The only kinda scary thing I saw was the rear wheel arch... not sure what happened there, but I bet its fixable.
Old 01-24-2016, 02:22 PM   #25
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
You may want to check the roof air before moving. On mine bolts through the inside grill is all that holds the unit on. Without the inside grill mounted the rooftop unit is just sitting there and will slide right off.
Also for the windshield call a local glass shop, preferably someone who works on trucks, and they can order the glass and gasket, probably for less than you can, and install it with no hassle.
Good luck with your new toy.
Cheers, Dan
~ Margaret Thatcher ~
Old 01-24-2016, 03:43 PM   #26
Tap
Tap's Avatar
Tap's 1981 280 Motorhome (Purchased January 2016)
Thanks so much you guys, I really appreciate all of the helpful info and encouragement!
I am very excited to finally own an Airstream, though I will be even much happier once I remove all of the critter droppings, clean it all up inside, replace the smashed windows, remove the old carpeting, and get it running.
Old 01-24-2016, 04:41 PM   #27
Airstream Driver
1997 30' Excella
Images: 51
Who you gonna call.......??????
I do make house calls, but its a flute, Steve, not a pipe
The Piedpiper of Hamelin
1996 Airstream B190
AIR #13
Old 01-24-2016, 04:59 PM   #28
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
280
Do as much as you can, as fast as you can, before the excitement ends.
Get those kids involved too.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
