Old 06-16-2016, 09:40 AM   #253
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
All good ideas Martin! Thanks!
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 06-16-2016, 02:09 PM   #254
Originally Posted by martin300662 View Post
Have you considered taking in out and repairing/strengthening on the reverse side?
Having recently gone through the procesess of repairing the ABS front valance on my Argosy I can say that's really not as hard as it sounds to repair ABS.
I used pellets similar to these and mixed them with MEK.
There are a bunch of threads on Airforms about using ABS pellets and MEK.
Old 06-18-2016, 07:15 PM   #255
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I checked today and the one in my parts donor is in pretty good condition Tap, just has some small cracks in the corners.
It still has the courtesy light and the switch which turns it on when the door opens (sort of the reverse of a fridge light!).
If you want it I can try and get it out for you?
martin300662 is online now   Reply With Quote
Old 06-19-2016, 03:17 PM   #256
Tap
Tap's Avatar
Martin that would be fantastic!
Thank you!
Old 06-19-2016, 05:32 PM   #257
ASTailgate's Avatar
If you need any parts give me a shout. I have my airstream that I am getting ready to part out. I just bought myself an excella 1000 34ft replacement and and using some parts off of my 280.
ASTailgate is offline   Reply With Quote
Old 06-19-2016, 05:41 PM   #258
Tap
Tap's Avatar
Oh my gosh ASTailgate, thank you SO much!
I will make a list and get back to you soon! Thank you!
Old 06-19-2016, 05:48 PM   #259
Tap
Tap's Avatar
Gang, I don't know a d@mn thing about batteries, but I do know that my 280 holds 3 batteries that daisy-chain together, and that I need to buy all new ones.
I think I've heard that AGM batteries are best, but then I heard that gel batteries are best.
Which should I get? What voltage, 12? Or 6?
And what exact brand, model number, and store would be best?
Thank you SO much!
Old 06-19-2016, 05:56 PM   #260
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Tap, depends what you need and what equipment you have. The best are lithium, but they are pricey, and require very specific voltages during charging cycles.
Flooded are cheap, but need attention for water levels.
AGM are nice with lack of mx, but have a reduced Ah compared to flooded.
Are these for boondocking, starting, or puttering?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-19-2016, 06:12 PM   #261
Tap
Tap's Avatar
Tap's 1981 280 Motorhome (Purchased January 2016)
Hi Vycan!
I guess they would be for everything. Starting, using for interior lights, fridge at times, and I want to do boondocking, even though I don't have solar, etc.
So whatever could hold some good charge, last for quite awhile, etc.
and I'd prefer to not have to deal with maintaining water in them, and sadly I can't afford super expensive batteries.
(For boondocking I also have an Onan generator in an outdoor compartment in the rear with a starting button inside.)
Old 06-19-2016, 07:27 PM   #262
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Thank you!
I got all the screws out this afternoon Tap, but someone has been a little over zealous with the Vulkem on the corners where they meet the inner skins. If get it out when I go over to AS NE tomorrow. PM me you address and I will drop it in the mail to you.
Old 06-19-2016, 08:28 PM   #263
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Mark
You should have two coach and one starter battery. On my diesel the starter is also tied in with my coach for starting the diesel but on your gasser the starter maybe isolated from the coach batteries.
Vycan has gone over the types. The flooded or wet batteries can be a problem with the old univolt converter as it keeps throwing 14v at the batteries all the time if the coach is plugged into the mains, eventually the water will boil off and you will have fried your batteries if you don't maintain the levels. However if you change your Univolt to a Progressive Dynamics 12 converter with the charge Wizard, it has three charge settings and will automatically shut off and then trickle charge the batteries in order not to cook them.
There are also two types of wet and AGM cell batteries, deep cycle and auto cycle. Deep cycle are great for coach batteries as they can be depleted and recharged many times without damage, but have no starter boost stage for starting an engine. Auto boost batteries are for the one that starts your motor as it sends a big boost of energy to the starter to get things going but will be damaged if depleted all the time, so it is usually isolated from the coach batteries.
The feeling is to buy the biggest most amp deep cell wet or AGM battery for your coach batteries money can buy and will fit, then a good yellow top AGM starter battery for your engine start.
Interstate make good batteries, wet and AGM. So do Trojan, but are very pricey in comparison to Interstate, but have 200 amp/hrs 12 volt.
http://www.trojanbattery.com
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 06-19-2016, 11:58 PM   #264
Tap
Tap's Avatar
Thanks for all the great info Tony!
Old 06-20-2016, 07:14 PM   #265
Vycan's Avatar
Manhattan , Kansas
Optima yellow tops give you the most flexibility for the price. Also you can get three and use them for any of your needs.
Old 06-20-2016, 07:15 PM   #266
Vycan's Avatar
Manhattan , Kansas
Those three would last you all night without need for engine/generator
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 01:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 12:42 PM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 09:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 02:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 07:29 AM
