Old 05-10-2016, 07:20 PM   #239
The answer probably depends on where the leak is in relation to the cockpit. Assuming its behind the cockpit then fumes shouldn't be a problem as long as you're moving forward.
As far as whether or not you'll enjoy the trip is a whole different issue
Old 05-11-2016, 05:50 AM   #240
1978 28' Argosy 28
Tap, last summer we road tripped from TX to MN in our Argosy. Thankfully with a brand new exhaust system. On our way up we got caught up in a 3 hour traffic jam outside Oklahoma city. Creeping just enough that we had to idle for the entire duration. Even if we had all our windows open, had we still had the horrible exhaust leak underneath, the fumes would have made us all completely sick. I know one never plans on being stuck in traffic like this, but I can't tell you how happy I was to have that new exhaust. I've got 2 little kids, but even if it was just me and the wife I wouldn't have wanted to sit in the fumes. Well worth the expense to have things sealed up. Not to mention the sound difference while on the road. If you're header-back parts are good it shouldn't be too bad to either install some new manifolds or collector donuts to seal up your system. I'm all for fixing it first.
Ben
bpg_austin is offline   Reply With Quote
Old 05-11-2016, 06:02 AM   #241
1989 34.5' Airstream 345
Ebro , Fla Panhandle
For your sake definitely fix it sooner than later.
As far as the coach or engine goes, mine went many thousands of miles with some leaking and no apparent damage. Your results may vary.
tevake is offline   Reply With Quote
Old 05-12-2016, 09:52 AM   #242
SpiceStream's Avatar
1984 31' Airstream310
Sullivan , Wisconsin
Your engine wont sustain any damage unless the heat associated with the leak is directed at something that cant handle the given heat. The biggest issue is carbon monoxide, I would expect that everyone is already running a carbon Monoxide detector in their coach. the next biggest issue is creature comfort, a loud ride increases occupant fatigue.
SpiceStream is offline   Reply With Quote
Old 05-26-2016, 04:29 PM   #243
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Just checking in with you here Tap......how are things going with the rig??? You certainly earned the medal of honor for your attendance at the motorhome get together! Any news on the rig that youd like to share with the crazies here? Hope all is going well and moving along.
Mike
mayco is offline   Reply With Quote
Old 05-26-2016, 04:36 PM   #244
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Mike
I was starting to get concerned as I have emailed Mark and got no reply; hope everything is OK.
martin300662 is offline   Reply With Quote
Old 05-26-2016, 06:38 PM   #245
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Now that the meet is out of the way, probably catching his financial breath.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 05-29-2016, 11:06 PM   #246
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Tap, looking forward to hearing more about your motorhome.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-30-2016, 11:57 PM   #247
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Thanks for your interest Vycan, I'll put an update on here in the next couple of days. Take care bud.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 06-16-2016, 08:42 AM   #248
Tap
Tap's Avatar
Well the project continues.
Working on big things and small things.
For small things, does anyone know where I can get one of these round lights that shines on my interior step?
There's just a hole where mine used to be. I got a photo of this elsewhere.
Name:	ImageUploadedByAirstream Forums1466084518.308559.jpg
Old 06-16-2016, 08:44 AM   #249
Tap
Tap's Avatar
Tap's 1981 280 Motorhome (Purchased January 2016)
Also, does anyone know where a fella could find a replacement molded interior step?
Mine is cracked:
Name:	ImageUploadedByAirstream Forums1466084640.345700.jpg
Name:	ImageUploadedByAirstream Forums1466084679.391190.jpg
It's ok for now, but someday the crack will get worse.
Old 06-16-2016, 08:45 AM   #250
Tap
Tap's Avatar
Old 06-16-2016, 09:00 AM   #251
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Attachment 264580
These are very common snap-in courtesy/license plate lights Tap. More typically supplied in chrome but easily painted to match. You should be able to pick them up in your local auto-part store.
Old 06-16-2016, 09:02 AM   #252
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Mine is cracked:
Attachment 264581
Attachment 264582
Have you considered taking in out and repairing/strengthening on the reverse side?
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 01:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 12:42 PM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 09:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 02:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 07:29 AM
