Old 05-08-2016, 01:06 PM   #225
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Tap's 1981 280 Motorhome (Purchased January 2016)
Just double checking.
Does everyone else agree that the air pressure for my 280's brand new tires should be 75 psi in the front and 60 psi in each of the rear tires?
Thanks again Bkahler.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 05-08-2016, 03:09 PM   #226
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Tap, people run a wide variety of psi in their MOHO tires. I believe in the owners manual it calls for pressure as low as in the 55psi range, and some folks run them that way. Ive read others who run at maximum tire pressure which is over 100psi. So, to get a spot on answer depends on who you talk to I suppose. There are good arguments to be made on both sides of that fence. Personally I run 75 up front and a bit higher in the rear. Youll find what youre comfortable with once youve had it out a few times. I believe you are quite safe to start out with 75psi all the way around. Lower pressures will give you a softer ride. Youll need to consider manufacturer specs, comfort of ride, wear patterns, handling, etc etc. I wish there was a dead on answer on tire psi but not sure there is.
Mike
mayco is online now   Reply With Quote
Old 05-08-2016, 03:36 PM   #227
Tap
Tap's Avatar
Mike, thanks, that's helpful.
I just don't have an owners manual, so I don't have anywhere to look for my exact machine.
Thanks so much!
Old 05-08-2016, 04:25 PM   #228
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Mike is right as everyone has his or her personal taste and ride comfort. It would also depend on what model coach you have, as a 350 is considerably heavier than a 250 and a diesel is 400+ lbs heavier up front than a gasser.
FYI I did come across an Airstream placard with my paperwork somewhere that stated air pressure of 70 PSI front and rear for my 310; HOWEVER I query that since the diesel was very much an adhoc option and rare, I'd be thinking 70 PSI is for the gasser.
I know John runs higher pressures as higher PSI's lower tire temperature and you don't want the rears bellying together as that will increase heat in the tires, so I have just bought an infared thermometer and will start taking temps of the tires at different pressure ranges until I find that sweet spot.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 05-08-2016, 04:59 PM   #229
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
When you buy your tires have the dealer provide you with the Load/Inflation chart for your tires. Every manufacturer will have a weight capacity per inflation usually in 5 psi. increments. There will also be a different capacity if the tire is used as a single or dual.
For your 280 I would guess a ball park weight at 5000 on the front and 10000 on the rear. My 280 has a 14500 GVW and is a little heavier on the front with the diesel but real close to 10000 on the rear. If you find a scale weigh it but the above numbers will get you a starting point if you can't find a scale.
I run mine at 70 front and 65 rear which is about 5 psi. high just for a little margin of error.
By the way I'm starting to get around better and I think I found a box to ship the seat bases in. PM me your address and I'll try to get them ready to go.
Cheers, Dan
~ Margaret Thatcher ~
Old 05-08-2016, 10:09 PM   #230
Tap
Tap's Avatar
Thanks for all the tire info everyone!
My mechanic noticed that the belt behind the grill for my air conditioner was missing. But he was out of that belt at the time.
What belt is that? Is it a common size that I can find in any auto parts shop?
Or will I have to order it online and not get it in time for my long drive to Penn Wood?
Thanks!
Old 05-09-2016, 04:38 AM   #231
Dazed and Confused
Isuzusweet's Avatar
Tap
There probably is a bigger reason your A/C belt is missing. Mine is missing also as the compressor is seized, I would do a system load check for leaks before spending large coin in getting a poor system design up and running.
You're not going to need it on this trip as you'll have plenty of air flow with the windows.
Just MHO
Tony
Old 05-09-2016, 05:22 AM   #232
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Over-inflation gives you a rough ride and is hard on the Airstream structure
Under-inflation is a tire killer due to heat build up.
A good estimate to use when comparing tire pressure to air temperature is for every 10 degrees F, tire pressure will adjust by 1 psi. For example, if the outside air temperature increases 10 degrees, the tire pressure will increase by 1 psi. Conversely, if the air temperature falls 10 degrees, the tire pressure will decrease by 1 psi.
Considering these facts, you want to make sure that your tire pressure does not exceed +~10% of cold inflation.
Here is an example that will surprise you:
You start out in the morning with 70 psi on the front @ 60 degrees F
By noon it is 100F and your tire pressure 84psi
You would think you overinflated your tires and make the huge mistake to lower the PSI even more. The reality is that you underinflated the tires, which caused the psi increase due to excessive heat
70 psi plus Temp increase (4psi for 40F)=74psi
But 70psi to 84psi=20% increase
In the above scenario you would want to see ~77 max psi at noon
Moral, check your cold inflation versus warm, considering outside temp
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-09-2016, 06:03 AM   #233
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Tap, Whenever I look for a noise like a bearing squeal, a ticking sound or an exhaust leak I use a stethoscope to pinpoint the source of the noise. I got mine with a blood pressure cuff at the local drug store. You will be surprised how a loud noise like an exhaust leak will echo around under a vehicle and give you the impression it is coming from somewhere else. With a stethoscope you can pinpoint the location.
Gregsch is offline   Reply With Quote
Old 05-09-2016, 08:51 AM   #234
SpiceStream's Avatar
1984 31' Airstream310
Sullivan , Wisconsin
Originally Posted by tevake View Post
Both the exhaust manifold to head connection and the back of the headers connection to the tail pipe are suspect and common leak points.
Hopefully the parts are OK. So you can get gaskets and just bolt things back together.
There is some question about the use of gaskets between the manifold and the heads. I just installed gaskets there and am happy with the results.
Between those and new donut gaskets at the collector pipe the noise as well as fumes in the cabin are MUCH MUCH IMPROVED!
It's nice that there is so much clearance under these coaches that its possible to crawl around and check out these things with out a lot of jacking etc.
CHEERS Richard
I have used Remflex exhaust manifold gaskets in the past with 100% success, even in applications that "ALWAYS LEAK". They are great. I would not consider pulling an exhaust manifold without having a set to go back in. I have spent up to a month of weekends drilling out broken exhaust manifold bolts, tapping heads, and replacing all hardware with stainless studs and brass nuts. It can be an easy job, but that has not been my experience every time. http://catalog.remflex.com/
Good luck.
SpiceStream is offline   Reply With Quote
Old 05-09-2016, 10:23 AM   #235
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Tap any news on the exhaust leak . Is it the manifolds or just the donut gasket
shepherd57 is online now   Reply With Quote
Old 05-09-2016, 12:49 PM   #236
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Good link there Spicestream. If I ever have to revisit that part of the exhaust again I'll round up a set of their gaskets and a set of new bolts.
I too have had challenges while working on old exhaust parts and was dreading the possibilities on the 454. This actually held me off of starting the job for a while. Once I realized there was pretty good access thru the wheel wells my reluctance eased a lot. With a straight shot at the bolts with an impact wrench the removal became quite doable. And all of the bolts came out cleanly.
It turned out there were no gaskets in place, and clear signs of leaking on both sides of the engine.
I've driven over 500 miles since doing the gaskets and all is going well so far.
Replacing the donut gaskets done earlier in my ownership made the most improvements in noise and fumes. But getting the manifolds well seated really finishes the process nicely.
Cheers Richard
tevake is offline   Reply With Quote
Old 05-10-2016, 08:06 AM   #237
Cheers Richard
The last set I did was on a class C SOB last summer, there was only 1.5" clearance between the firewall and Exhaust manifolds, it was no fun. it was also a 351 which is allot more prone to exhaust manifold warping and cracking than the 454. All of my smashed fingernails finally grew back in.
Old 05-10-2016, 02:28 PM   #238
Tap
Tap's Avatar
They are checking out my exhaust manifold issue right now.
Question...
If it becomes impossible to get it fixed before the rally, is there anything bad about me taking the trip with it as is?
It's loud and a bit exhaust-y, but if I don't mind the noise and I ride with the windows open so that I have fresh air to breathe (I have to anyway, because I'm missing Windows, hahaha!), then is there anything wrong with me taking it to the rally as is?
Or is that a huge mistake?
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
