Old 05-04-2016, 04:08 PM   #211
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Tap's 1981 280 Motorhome (Purchased January 2016)
It's finally nice out in Minnesota!!!
Friday 86į!!!!
Name:	ImageUploadedByAirstream Forums1462396095.548587.jpg
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 05-04-2016, 04:10 PM   #212
Tap
Tap's Avatar
Originally Posted by martin300662 View Post
Yes Tap, there is a square plastic panel that slides out of the way to give access to the lock if opening from inside.
They are available from the online retailers or Airstream but come in a couple of different sizes so you need to be careful to get the right in.
The square hole measures 8" tall by 6" wide.
Old 05-04-2016, 04:13 PM   #213
Tap
Tap's Avatar
Looks like this is what I need and then I'll have to trim it slightly.
http://www.vintagetrailersupply.com/...p/vts-1492.htm
Old 05-04-2016, 05:45 PM   #214
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Sure looks like it Tap
martin300662 is offline   Reply With Quote
Old 05-04-2016, 06:52 PM   #215
Tap
Tap's Avatar
Is there anything that can be done for rust rings on the laminate counter and rust on the cooktop cover?
Name:	ImageUploadedByAirstream Forums1462405896.580780.jpg
Old 05-04-2016, 07:19 PM   #216
Elbow grease?!
Old 05-06-2016, 01:42 PM   #217
Tap
Tap's Avatar
Guys, my 210 is now running well, but it is *SUPER* loud when I accelerate.
It's quiet enough when it's just idling, but whenever I push down on the gas peddle it sounds just like a Harley Davidson convention.
Super loud inside and outside. It sounds like it's right up front. That can't be normal. We wouldn't even be able to talk in the RV.
So what is that?
My guess is the exhaust must not be connected or has a big hole, so it isn't being muffled by the muffler?
Do you think that's it?
Old 05-06-2016, 01:52 PM   #218
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Cracked/broken exhaust manifold or do-nut gasket-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-06-2016, 02:05 PM   #219
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Lift your engine cover and see if you can isolate where the leak is. That is, if you think its coming from up front. If not there, youre going to have to get underneath and inspect your exhaust.
mayco is offline   Reply With Quote
Old 05-06-2016, 03:03 PM   #220
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Both the exhaust manifold to head connection and the back of the headers connection to the tail pipe are suspect and common leak points.
Hopefully the parts are OK. So you can get gaskets and just bolt things back together.
There is some question about the use of gaskets between the manifold and the heads. I just installed gaskets there and am happy with the results.
Between those and new donut gaskets at the collector pipe the noise as well as fumes in the cabin are MUCH MUCH IMPROVED!
It's nice that there is so much clearance under these coaches that its possible to crawl around and check out these things with out a lot of jacking etc.
CHEERS Richard
tevake is offline   Reply With Quote
Old 05-06-2016, 06:11 PM   #221
Don't dispare if the manifolds need work, access thru the wheel wells make them quite reachable.
Cheers Richard
Old 05-06-2016, 06:21 PM   #222
Tap
Tap's Avatar
Cool. Thanks guys.
I'm just desperate to get it fixed before the lonnngggg drive to PA, or else it will be an extremely loud and dangerously exhaust-filled road trip.
On a happy note, I'm getting the brand new tires tomorrow!
Old 05-07-2016, 03:54 AM   #223
Tap
Tap's Avatar
Regarding my new tires for my 1981 280, they are 8r-19.5
What air pressure should I keep them inflated at?
Also where do I look that up? I don't have a manual for my 280.
Thanks!
Old 05-07-2016, 06:17 AM   #224
On my 310 I used to run 75 psi in the front and 60 psi in each of the rear tires.
Seemed to ride nice at those pressures.
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 01:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 12:42 PM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 09:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 02:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 07:29 AM
