Old 04-28-2016, 05:34 PM   #197
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
I'll try to get as much parts info as possible. Thanks.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 04-28-2016, 05:36 PM   #198
Tap
Tap's Avatar
Guys, where can I get a replacement light and red lens for this missing one?
Name:	ImageUploadedByAirstream Forums1461886569.534699.jpg
Thanks!
Old 04-28-2016, 06:19 PM   #199
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Attachment 261515
Thanks!
They are pretty common marker lights Tap.
Airstream Supply have them, but most folks change to LED to reduce load on the headlight switch.
http://airstreamsupply.com/Airstream...ssic-motorhome
martin300662 is offline   Reply With Quote
Old 04-28-2016, 06:57 PM   #200
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
You should be able to get them at any parts house or heavy truck supply or truck stop. How many do you want I have some spares.
shepherd57 is offline   Reply With Quote
Old 05-02-2016, 09:48 PM   #201
Look at thread "Clearance Clearance lights".
Old 05-03-2016, 04:49 PM   #202
Tap
Tap's Avatar
Thanks guys. I ordered one through VintageTrailerSupply.
Old 05-03-2016, 05:23 PM   #203
Tap
Tap's Avatar
Ok, today they finally finished all the tons of tuneups under the proverbial hood.
The brand new radiator is installed and good to go. I'll get specific part and company info on the radiator when I pick up my 280 tomorrow and I'll post it here.
Next stop to get my set of new tires installed.
So far so good for staying on schedule to make it to Penn Wood at all costs (literally).
My airstream will be mostly a silver tent on wheels during the Penn Wood trip because I won't have had time to test (or fix if needed) any of the inside appliances or plumbing beforehand, but at least it can (hopefully) mechanically make it to the rally.
I hope Penn Wood has a bathroom and shower for me to use while I'm there. Hehe!
Old 05-03-2016, 07:15 PM   #204
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Tap
No worries mate, all of us will have fresh water and a BBQ you can use. I always shower at the campground as the shower in my 310 doesn't really fit my 6'3" frame. Just go out and get an electric cooler if you're unsure about your fridge. If you haven't got your propane system checked yet I would buy a ceramic heater for heat.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 05-03-2016, 07:49 PM   #205
Tap
Tap's Avatar
Thanks Tony, that all sounds great.
I'm also going to bring a few gallon jugs of fresh water.
Old 05-03-2016, 08:15 PM   #206
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Tap, I suspect with the gear heads, spare parts, and knowledge base attending the Get Together any issue you have going into the weekend will be fixed before you leave!
I am a little like Tony, the on-board wetroom is for when no other option is available and typically use the campsite facilities. If all else fails I hear Brad has a hotel room nearby!
Old 05-04-2016, 01:00 PM   #207
Tap
Tap's Avatar
Very cool.
I can't wait to meet all of you guys.
Old 05-04-2016, 01:02 PM   #208
Tap
Tap's Avatar
Am I missing a piece here on my screen door? Is there a sliding piece or something that normally covers this gaping square hole?
Name:	ImageUploadedByAirstream Forums1462388535.720113.jpg
Name:	ImageUploadedByAirstream Forums1462388548.220072.jpg
Name:	ImageUploadedByAirstream Forums1462388559.590703.jpg
Old 05-04-2016, 01:53 PM   #209
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Yes Tap, there is a square plastic panel that slides out of the way to give access to the lock if opening from inside.
They are available from the online retailers or Airstream but come in a couple of different sizes so you need to be careful to get the right in.
Old 05-04-2016, 01:59 PM   #210
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Must be sunny where he is ......
bobmiller1 is offline   Reply With Quote
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
