Old 04-20-2016, 06:01 AM   #169
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Hang in there Tap. You set yourself a pretty ambitious goal to have the 280 ready for a several hundred mile trip in just a few months after purchase. As you said, your rig had sat for many years and bringing it back to road worthiness is going to take a good deal of time and money. Better to have these issues show themselves while youre at home than out on the road somewhere. Between replacing the glass, new tires, brake work, etc., you have tackled some of the most expensive items on your rig......ouch! But.....better to take care of things while at home than half way to Penn Wood right? Hang in there Tap.........oh, and thoroughly inspect your ball joints.
mayco is offline   Reply With Quote
Old 04-20-2016, 06:16 AM   #170
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1461154555.351083.jpg
Old 04-20-2016, 07:38 AM   #171
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Upgrading your cooling system is one of the better jobs to get done on our rigs. Solving the engine temp issue is so comforting. No more fan clutch kicking in all the time, no more nervously watching the temp gauge while stuck in trafic or climbing a long hill.
I had my radiator recorded with a hi performance core for around $500 , installed new water pump, hoses, redid the air dam etc. this resulted in an average 15 degree running temp drop. And much more relaxed driving experence.
It all does take some time and more cash than we would like, but that's the deal with these old units. Could have forked out the big $s going in for a newer coach. And still be forking out for its maintainance and repairs from all the stories.
I hear you about the gathering, I've been reading along and feel the excitement of joining in and meeting so many other classic caretakers. Very tempting.
But at this point with your revival strongly under way, getting these significant jobs done well is going to pay big rewards once you have them wrapped up and are out enjoying your nicely running, dependable rig.
This gathering is shaping up to be multiples of the first one in Colo. The next one may be a blooming festival.
You seem to be accomplishing so very much on your coach these days. Take comfort in that and keep the ball rolling while you have the momentum.
There is something to be said for the rolling restoration. Ie. break jobs down into sections that will allow some fun use as you go along. Once you get the basic mechincal systems sorted.
Hang in there Tap. You are doing great.
Cheers Richard
tevake is offline   Reply With Quote
Old 04-20-2016, 08:28 AM   #172
When we first got the 310 in late January of 06 it didn't make it's next trip for 6 months due to all the issues that had to be fixed. It wasn't safe to drive the way we got it. I had to do all the work myself which is why it probably took 6 months.
Hang in there, once you've got the big jobs out of the way the rest is gravy....yeah right
Old 04-21-2016, 07:44 AM   #173
Tap
Newbie -- 1981 280 MoHo
Tap's Avatar
1981 28' Airstream 280
Minneapolis/St. Paul , Minnesota
Thanks for the encouragement and well wishes guys, that really helped.
"The Aluminum Falcon"
1981 Airstream 280 (28') Motorhome
Tap is offline   Reply With Quote
Old 04-21-2016, 08:09 AM   #174
Tap
Tap's Avatar
This is my radiator:
Name:	ImageUploadedByAirstream Forums1461247777.855989.jpg
Name:	ImageUploadedByAirstream Forums1461247789.305882.jpg
Old 04-21-2016, 08:24 AM   #175
mayco's Avatar
Like Brad said, find an old school radiator shop and see what they can do with it. Mine got busted up pretty bad during a mishap with my harmonic balancer.....just a month or so after I took ownership. A local shop, thats been around for years here, was able to repair it and Ive had zero problems with it since. Give it a shot, ya never know.
Old 04-21-2016, 08:30 AM   #176
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
As long as the headers (top and bottom pieces) ate in good shape a recore is the way to go. Also see if an additional row of tubes can be added which increases cooling.
Dennis
dennis3751 is offline   Reply With Quote
Old 04-21-2016, 12:57 PM   #177
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
That's what I did...re-used my original tanks...I don't think there are two of the same radiators in any of our Airstreams !!! I put a four row core to fill the whole cavity and increased the tube size from 7/16 to 9/16...probably why it cost a million dollars ($985.00). regards, Bob
bobmiller1 is offline   Reply With Quote
Old 04-21-2016, 02:22 PM   #178
Tap
Tap's Avatar
My mechanic found a brand new one for $800. I'm going that route. It will be good in the long run, but so far I've put about $8,000 into this RV, still have to put about $1,500 more into new tires, still have to get the breaks replaced and new bearings packed, and I still haven't even driven it.
Even worse yet, I haven't tested the plumbing or any appliances inside yet, so this is just the beginning of the big payout.
I dream about someday enjoying the thing.
Old 04-21-2016, 02:27 PM   #179
Can you find out from your mechanic where he found the brand new one?!
In the hopes of making you feel better (and me worse!) I've got a LOT more than that in vested in my 74 Argosy and it doesn't have an engine or transmission installed yet or even an interior
Old 04-21-2016, 05:23 PM   #180
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Maybe we should share the Peanut spreadsheet so folks can see the cost of parts to just getting a unit back on the road, that has recently (less than 5 years) been used, and with a parts donor to contribute all the missing/bent bits, and with no labor costs (but a big 'favor' pile mounting up!)?
Cost comparisons to Bella (which now is officially the same as the list price on a brand new Ferrari F12 Berlinetta and nearly that of a Lamborghini Aventador LP700-4) would not be fair, but these things are the definition of a money pit.
martin300662 is offline   Reply With Quote
Old 04-21-2016, 05:34 PM   #181
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yeah Tap, hang in there mate as it does eventually slow down. Make sure you get the newest date coded tires you can, to put off having to shell out for tires later, rather than sooner.
When I bought my rig I spent a pretty penny buying it, but it was roadworthy and had been used regularly; that didn't stop me having to put a couple thousand into it to fix things but it certainly wasn't the big shock one can get when buying a barn find.
Speaking of barn find, I recently shocked an elderly gent selling a 345 that he hasn't used in 15 years by telling him that it would cost me a minimum $10,000 to get his rig on the road; let alone fixing interior or cosmetic stuff. He thought I was insane.
PS Give us info on the new rad and what hoses your mechanic found for your coach.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 04-21-2016, 05:39 PM   #182
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by Isuzusweet View Post
...selling a 345 that he hasn't used in 15 years by telling him that it would cost me a minimum $10,000 to get his rig on the road; let alone fixing interior or cosmetic stuff. He thought I was insane.
Cheers
Tony
Well rightly so, Tony. He knew it would cost at least 15 000
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Traveling Baja California January 2016 ghamr On The Road... 14 04-22-2016 12:41 PM
January 2016....photo contest LittleLucy Photography 34 02-02-2016 11:42 AM
First trip as a Snowbird, Mi to Fl in January 2016 LakeState On The Road... 22 10-08-2015 08:15 AM
Hello, newbie here. We just purchased a 1981 27RB International for 6800 hope... msasse Member Introductions 6 01-19-2015 01:45 PM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
