Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-14-2008, 03:53 PM   #1
Robfike's Avatar
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia , Alabama
Tag brake resistor
This question is for anyone with a 345, and the Kelsey-Hayes tag brake control. This set-up has the "Selective Resistor" mounted on the front driver side of the fire wall near the Isolator. What I need to know is if yours has the little bridge over the coils. This unit is what decides the maximum voltage that can go to the tag brakes.
Thanks, Rob
Robfike is offline   Reply With Quote
Old 10-16-2008, 07:46 AM   #2
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
Up-date,
I used two aircraft Adel clamps with the rubber removed, and bolted together. These fit perfectly. I adjusted the clamps to give me about 9.5 volts to the brakes at max. The test drive was great! I have never had the tag brakes working, so the braking is MUCH better.
If anyone wants, I can post a picture or two of the installation.
Rob
Old 10-17-2008, 08:13 AM   #3
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Originally Posted by Robfike View Post
Up-date,
Rob
Please do.
It took a while adjusting the tag brake controller until we got it right where the tag wheel wouldn't lock up. About 20 minutes in all driving back and forth which got us lots of bemused onlookers!
elbundi is offline   Reply With Quote
Old 10-20-2008, 07:30 AM   #4
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
Sorry it took so long but here are some pictures. The first shot is of the resistor in our MH. The second is of the drawing in the owners manual. The third is of the type of clamp I used. I just removed the clamp's rubber cushion.
Rob
Name:	selective resistor 001.jpg
ID:	69902   Click image for larger version
Name:	selective resistor 003.jpg
Name:	selective resistor 002.jpg
Tag Axle brake controller questions.. swinginping Brakes & Brake Controllers 0 03-30-2008 09:01 PM
controller for tag axel brake lorcan Classic Motorhomes 5 07-01-2005 09:32 AM
Tag Axle Brake Parts swebster Mechanics Corner - Engines, Transmission & More... 5 10-12-2004 06:59 AM
Tag Axel Brake Voltage / Amperage 87MH Mechanics Corner - Engines, Transmission & More... 1 11-11-2003 09:25 AM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
