1987 32.5' Airstream 325
Windsor
, Ontario
Tag axle tire replacement
I have an '87 325 MH.
Tag axle tire(passengers) tire blew on the highway and I had a tire service replace for me.
Now back home I'm trying to replace and put new tire back on.
Is there a proper method to doing this, I can't seem to get that tagaxle tire off the road?
Chris
If you some 2x10s just lay 2 down on top of each other in front of the drive axles and drive up on them. The tag axle should be clear of the ground and you won't need a jack.
