Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-23-2016, 09:43 AM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Tag axle tire replacement
I have an '87 325 MH.
Tag axle tire(passengers) tire blew on the highway and I had a tire service replace for me.
Now back home I'm trying to replace and put new tire back on.
Is there a proper method to doing this, I can't seem to get that tagaxle tire off the road?
Thanks in advance as always,
Chris
realpank is offline   Reply With Quote
Old 10-23-2016, 09:35 PM   #2
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Chris
If you some 2x10s just lay 2 down on top of each other in front of the drive axles and drive up on them. The tag axle should be clear of the ground and you won't need a jack.
shepherd57 is offline   Reply With Quote
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 9 04-21-2020 10:57 AM
1986 345 Tag Axle Replacement Docseuss Classic Motorhomes 6 09-06-2016 05:26 AM
Looking for a replacement hub to fit my tag axle Mr. D Classic Motorhomes 8 04-10-2010 03:36 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 12:48 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
