Well thanks for all the info for the tag axle project , this weekend hopefully finish brakes then drop drive shaft to replace u joints and fix E brake , replaced trans rear seal , replace harmonic balancer , rebuild leveling stab , replace front air bags , replace drive axle shocks , tag axle rebuild , change electric fuel pump , replace all rubber fuel lines , remove mechanical fuel pump , change drive axle lube , trans flush , power wash under side paint , replace stock exhaust manifold with large tube headers , replace intake and carb , rebuild slide draws and battery box , replace windshield wiper blades , strip old wore out nasty gray paint , repaint strips . Hopefully this list disappears like Hillary's e-mails LOL
