Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-23-2006, 12:48 PM   #1
Howard Lefkowitz
Profile:
Tachometer instability
Over the last several months my Tach has been changing over a 1500 rpm range. This was even more pronounced after we changed the plug wires two weeks ago. I found that I could change the reading just by moving the pickup coil around the #5 plug wire. I moved the pickup coil to plug wire #1 and inserted a 1/4 inch ceramic insulator in the coil/core which held the wire core tightly in place. The insulator is about 1 1/2 inches long and sticks out of the sensor core on both sides. I taped the ceramic to the spark plug wire so it would not move. Solid and correct tach readings have resulted.
Howard Lefkowitz is offline   Reply With Quote
Wandering tachometer Geophilist Mechanics Corner - Engines, Transmission & More... 21 10-25-2006 04:25 PM
Tachometer failure!! ralley Mechanics Corner - Engines, Transmission & More... 5 02-24-2006 06:04 PM
Where is the tachometer connection? AccessMaster Mechanics Corner - Engines, Transmission & More... 13 06-29-2003 05:26 PM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
