07-10-2015, 11:33 AM
1987 32.5' Airstream 325
dripping springs
Suction cup dent puller
Ok, I know for the purist this will be inadequate, but for my purposes it is great! Below are before and after pics of the giant dent in my roof that has be significantly minimized with a suction cup pneumatic dent puller. The plan is to now remove the 'headliner'/plastic cap replace some wiring, foam insulate the space (to give some strength to the panel) then replace the headliner.
-Bill
07-10-2015, 11:36 AM
1966 26' Overlander
Woodstock
nice work. I use(d) a car type suction cup a few times and was happy with the results. I freaked out a guy a little by pulling a dent out his Airstream that he thought was unfixable. It popped right back to its original shape.
07-10-2015, 12:30 PM
1999 30' Excella 1000
small town
, Maryland
Looks a lot better Bill. I've used a new toilet plunger to pull out car dents. Only if there's no wrinkle in the dent. A heat gun will remove some dents in plastic car bumpers. You tube can save you money... just search. Thanks for sharing
07-10-2015, 01:23 PM
1960 28' Ambassador
1998 25' Safari
Avonton
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
07-10-2015, 04:45 PM
dripping springs
That's the one!
-Bill
07-10-2015, 04:50 PM
1969 25' Tradewind
Shasta Lake
Thanks for the tool tip .
It should come in handy removing the P.O. damage over the front window.
07-11-2015, 11:40 AM
1984 31' Excella
1976 Argosy 24
Olsburg
, Kansas
good idea
very good idea, if a person wants the totally smooth than go for it. At least you have gotten rid of most of the dent. I had one taken out of my Excella at a dealership. Overall it looks good, a person really has to look close to see what is left from the dent. I still have a dent on the rear that was done by the previous owner, I am guessing a backing int overhand. I think I will try the dent puller myself. My and I had talked about that possibility but never carried it through. Thanks for the information.
07-11-2015, 12:10 PM
2014 25' Flying Cloud
Cohasset
, Massachusetts
Secret DeDenter man!
Originally Posted by Shacksman
You are funny!
07-11-2015, 03:03 PM
beaumont
dent
Really good job. I gotta have one of these.. on the way to harbor freght,
07-11-2015, 04:10 PM
2009 34' Classic
North Richland Hills
How do you know how much air pressure from the compressor to use?
Plus, it only has 4" & 5" cups. Is that small enough for small 1" to 3" dents?
Rod & Teresa "On the road again."
07-11-2015, 04:23 PM
2002 30' Classic S/O
Fleming Island
The puller runs a stream of air from the compressor over an orifice that creates the vacuum in the suction cup by the Bermouilli principle (google it). Run the compressor wide open.
I also used the HF tool to minimize the damage from a driveway incident but my dent was also creased so I ended up getting the panel replaced at Out of Doors Mart. They did a great job. The panel and the rivets look original.
Al
07-11-2015, 04:30 PM
Alamo Heights
Google will probably still find it, but it's "Bernoulli's principle"
— David
07-11-2015, 06:30 PM
1961 16' Bambi
1969 27' Overlander
Bonner Springs
, Kansas
Thanks for the info on the dent puller. I may look into after the first of the year..
Our '69 has a dent in the curb side rear end cap..
Martin
07-13-2015, 08:58 AM
2013 30' Classic
Greenwood
, Mississippi
That works great on huge dents, but does it work on tiny dents like hail dings?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
07-13-2015, 03:17 PM
1978 25' Tradewind
Metro Phoenix
Probably not. I've got a couple of the "hot glue" pullers that they say will not work on aluminum whatsoever, in any way, shape, or form.
But, of course, I'm gonna try 'em anyway. They're small enough to do hail-size dents.
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
07-13-2015, 03:43 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
having been a party to Doug's dent pulling marathon a couple of years ago, I'd say we were quite pleased with the results!
your success will depend on the size and nature of the dent, and learning the feel of a pneumatic suction tool. go slow, and be patient as you try it out.
thanks, again, Doug!
ymmv....
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
07-13-2015, 03:45 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
and, you might also want or need a ladder, too....
be careful up there!
Joseph & Gabrielle
07-13-2015, 03:53 PM
2013 30' Classic
Greenwood
, Mississippi
I wonder if the dent puller will help the dents from vandalism- still not very big, but a little bigger than hail dings. I guess that's why the lady wants us to make an appointment with the paint-less dent repair man- to see if he can help us out.
TAC #MS-10
Airforums #70955
07-13-2015, 07:52 PM
dripping springs
I've also seen the heat followed by cold co2 trick and thought I'd try it on some of my dimples. I'll let you (collective) know if it works or not.
-Bill
