Old 07-10-2015, 11:33 AM   #1
gaiaenviro's Avatar
1987 32.5' Airstream 325
dripping springs , Texas
Suction cup dent puller
Ok, I know for the purist this will be inadequate, but for my purposes it is great! Below are before and after pics of the giant dent in my roof that has be significantly minimized with a suction cup pneumatic dent puller. The plan is to now remove the 'headliner'/plastic cap replace some wiring, foam insulate the space (to give some strength to the panel) then replace the headliner.Click image for larger version
Name:	ImageUploadedByAirstream Forums1436549532.006844.jpg
ID:	242605Click image for larger version
Name:	ImageUploadedByAirstream Forums1436549551.499172.jpg
ID:	242606Click image for larger version
Name:	ImageUploadedByAirstream Forums1436549565.039323.jpg
-Bill
gaiaenviro is offline   Reply With Quote
Old 07-10-2015, 11:36 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
nice work. I use(d) a car type suction cup a few times and was happy with the results. I freaked out a guy a little by pulling a dent out his Airstream that he thought was unfixable. It popped right back to its original shape.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-10-2015, 12:30 PM   #3
1999 30' Excella 1000
small town , Maryland
Looks a lot better Bill. I've used a new toilet plunger to pull out car dents. Only if there's no wrinkle in the dent. A heat gun will remove some dents in plastic car bumpers. You tube can save you money... just search. Thanks for sharing
streaminwild is offline   Reply With Quote
Old 07-10-2015, 01:23 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I took the same type of dent puller to a rally and pulled out some dents when people weren't around. They couldn't figure out what happened , thought the sun must have popped them back out.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-10-2015, 04:32 PM   #5
FYI, Harbor Freight makes a very affordable one...
Dent Puller - Save on this Pneumatic Dent Puller
Old 07-10-2015, 04:45 PM   #6
gaiaenviro's Avatar
That's the one!
-Bill
Old 07-10-2015, 04:50 PM   #7
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Thanks for the tool tip .
It should come in handy removing the P.O. damage over the front window.
Name:	TW Rt Frt i.jpg
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is online now   Reply With Quote
Old 07-11-2015, 11:40 AM   #8
clydecrashcu's Avatar
1984 31' Excella
Olsburg , Kansas
good idea
very good idea, if a person wants the totally smooth than go for it. At least you have gotten rid of most of the dent. I had one taken out of my Excella at a dealership. Overall it looks good, a person really has to look close to see what is left from the dent. I still have a dent on the rear that was done by the previous owner, I am guessing a backing int overhand. I think I will try the dent puller myself. My and I had talked about that possibility but never carried it through. Thanks for the information.
clydecrashcu is offline   Reply With Quote
Old 07-11-2015, 12:10 PM   #9
2014 25' Flying Cloud
Cohasset , Massachusetts
Smile Secret DeDenter man!
You are funny!
Tan Son Nhut is offline   Reply With Quote
Old 07-11-2015, 03:03 PM   #10
beaumont , Texas
dent
Really good job. I gotta have one of these.. on the way to harbor freght,
Dixie722 is offline   Reply With Quote
Old 07-11-2015, 04:10 PM   #11
4Kilefamily's Avatar
2009 34' Classic
North Richland Hills , Texas
How do you know how much air pressure from the compressor to use?
Plus, it only has 4" & 5" cups. Is that small enough for small 1" to 3" dents?
Rod & Teresa "On the road again."
4Kilefamily is offline   Reply With Quote
Old 07-11-2015, 04:23 PM   #12
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The puller runs a stream of air from the compressor over an orifice that creates the vacuum in the suction cup by the Bermouilli principle (google it). Run the compressor wide open.
I also used the HF tool to minimize the damage from a driveway incident but my dent was also creased so I ended up getting the panel replaced at Out of Doors Mart. They did a great job. The panel and the rivets look original.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-11-2015, 04:30 PM   #13
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Google will probably still find it, but it's "Bernoulli's principle"
David
Old 07-11-2015, 06:30 PM   #14
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
Thanks for the info on the dent puller. I may look into after the first of the year..
Our '69 has a dent in the curb side rear end cap..
Martin
hugheym is offline   Reply With Quote
Can this dent be removed with suction? groovzilla 1974 - 1979 Sovereign 11 11-28-2013 11:41 PM
Pro Quality Dent Puller? fotochop Ribs, Skins & Rivets 23 12-24-2010 06:50 PM
Dent Puller Zeppelinium Ribs, Skins & Rivets 12 07-03-2010 06:24 PM
DIY dent puller kit flmgrip Ribs, Skins & Rivets 9 06-07-2010 08:41 AM
Windshield Suction Cup Law rickandsandi Off Topic Forum 35 03-01-2007 09:25 PM
