Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 12-02-2009, 08:05 PM   #1
sharptalk's Avatar
scottsdale , Arizona
Storage upkeep
I've got my 345 at a storage place. It's been there for a month. What do Ineed to do to maintain it while parked there?
Karen & Jay
Former Owner of a 1987 Aistream 345
sharptalk is offline   Reply With Quote
Old 12-03-2009, 06:33 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I would suggest a solar battery charger or maintainer. Something to keep the batteries from going completely dead while it's parked.
Is it parked on a paved pad? Or at least good gravel? If it's on grass or dirt, then find out if you can place something under the tires for parking. Even 3/4 inch treated plywood is better on your tires than parking on dirt. It'll help keep the beastie from sinking into the dirt.
Some tire protection would be good as well. Spray them down with some tire protectant or cover them. Especially if they sit in the sun.
Chris
Chris
Old 12-03-2009, 06:40 AM   #3
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
All of the above Plus !
If stored outside, anyplace ? a good wash down every 2 to 4 weeks sure does help with the overall exterior condition and maintenance.
John H. is offline   Reply With Quote
Old 12-03-2009, 08:33 AM   #4
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Make sure you don't have mice very destructive critters.Start mh and generator every couple of weeks.
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 12-03-2009, 09:44 AM   #5
sharptalk's Avatar
It is on gravel. I will go and start it this weekend and cover the tires.
Karen & Jay
Old 12-03-2009, 10:45 AM   #6
Kevin245's Avatar
If you run the generator or the drive train it is a good idea to run it/them long enough that they come up to full operating temperature. This is usually accomplished by driving several miles. This helps drive out any condensation from the internals and exhaust systems.
The other benefit is that you work the brakes, suspension and other systems too, and you can swing by the local drive-in for a burger, fries and a shake while you're out.
Regards,
Kevin
William C. Swinney
Old 12-03-2009, 04:00 PM   #7
Silverton , Colorado
mothballs in a small mesh bag, hung on the sides of the engine will help discourage the wire-eating beasties...if you can't go for a drive, at least move the unit forward or backward to alter the surface contact of the tires..flip the battery disconnect switches to OFF, as there is usually residual draw, and the control panel on the fridge and the master control panel over the stove are drains...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 12-03-2009, 04:08 PM   #8
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
I flip off the battery disconnect and hook up a Battery Minder to keep the charge up.
Where are you storing in AZ and how much per month/length. May want to move mine to AZ so I can use it without coming and going in the snow!
mojo is offline   Reply With Quote
Old 12-03-2009, 07:33 PM   #9
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I store my trailer in a facility in El Mirage which is a little of Phoenix. All the covered spots are 12x40 and cost around $125 per month. The facility has no power for the sites, but they do have a dump station. It is very secure and has a key entry system at the gate. They do have some uncovered spots, but I have no idea what they cost.
PM me if you would like more information...
Richard
Old 12-08-2009, 04:48 PM   #10
sharptalk's Avatar
I drove it up to my local mechanic, filled the tires, drove back, ran the generator for a few minutes, turned off the batteries and covered the tires!
Karen & Jay
Old 12-08-2009, 04:50 PM   #11
sharptalk's Avatar
I am storing it at Storage Max in Scottsdale. $85/month for 34.5'. Lowered my insurance $41/month because it is in storage.
Karen & Jay
Old 01-25-2010, 03:52 PM   #12
sharptalk's Avatar
I needed to add back in the whole insurance policy yesterday. Turns out in Arizona, if it doesn't have full coverage they cancel your registration.
Karen & Jay
Old 01-25-2010, 03:58 PM   #13
3 Dog Nite's Avatar
Cleveland , Tennessee
As long as it's running, pull it forward then bcak into the parking spot if possoble. Keep from getting flat spot on tires if it will be parked a long time. Don't forget about antifreeze for the plumbing.
Ricky.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 01-26-2010, 07:02 PM   #14
N2XBW's Avatar
BRADENTON, On The Picturesque and Sunny West Coast of Florida, , USA, PLANET EARTH, MILKY WAY, LOCAL GROUP, SPIRALING SLOWLY THROUGH THE UNIVERSE
When winterizing the Airstream, it's good to blow out the water lines with compressed air. I lucked out and discovered this special winterize fitting at http://winterizemanufacturing.com/. It worked better than anyting I've used in the past. All usual disclaimers apply.
These aren't the droids you're looking for.
You can go about your business.
Move along.
N2XBW is offline   Reply With Quote
Old 01-26-2010, 09:10 PM   #15
sharptalk's Avatar
We don't freeze in the Phoenix area, but if I ever move to colder climes I will remember to winterize.
Karen & Jay
Old 01-27-2010, 10:03 AM   #16
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
This is what I use:
Blow Out Hose - Item - Camping World
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
dallas storage pbarstow Winterizing, Storage, Carports & Covers 7 08-23-2008 07:05 PM
Annual upkeep and maintenance questions??? Scotty C Full-Timing 4 05-09-2007 03:11 PM
Storage vigo On The Road... 3 12-29-2006 10:53 AM
Exterior refreshing and upkeep tslanier Cleaning, Stripping & Polishing 1 06-04-2006 07:13 PM
RV Storage jordandvm Off Topic Forum 15 07-25-2004 09:43 AM
