Old 12-09-2006, 03:02 PM   #1
Still no House Power
I am still on the hunt for this pesky problem. When I check for voltage at the battery I get 12.6/13.8 depending if I am on battery or shore/generator power. When I test at the individual circuit fuses, using the battery negetive fuse as the neg reference I get a neg voltage at the individual ckt fuse. I would think the output should be a positive 12vdc. This would explain my lack of house power. Has anyone experienced this, any thoughts on the cause
Alumi-Naught is offline   Reply With Quote
Old 12-09-2006, 03:16 PM   #2
1991 35' Airstream 350
Windsor , North Carolina
Check the components between your batteries and the fuse box. The first thing to check should be the solenoid mounted on the back of the battery box, followed by each piece of cable. The problem has got to be there somewhere. Also check the condition of each piece of cable for breaks in the insulation which would cause this problem.
ralley is offline   Reply With Quote
Old 12-09-2006, 07:28 PM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Only 4 things should cause a full 12VDC negative voltage at those points:
1) The meter is reading backwards (i.e. the wires in it are swapped)
2) You have the meter leads backwards
3) The positive and negative battery cables are connected to the wrong points on the fuse panel.
4) It's unlikely because of different battery terminal sizes, but battery cables on the wrong battery terminals could cause this
It should.
Reversed power polarity doesn't explain a loss of house power. It would not stop resistive devices like lights from working. DC motors should run, but backwards. Electronic devices without a protection diode would probably burn up. With one, they may or may not blow a fuse, depending on whether the diode is series or shunt.
Maurice
RoadKingMoe is offline   Reply With Quote
Old 12-10-2006, 06:55 AM   #4
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow Still no house power.
I am still on the hunt for this pesky problem. When I check for voltage at the battery I get 12.6/13.8 depending if I am on battery or shore/generator power. When I test at the individual circuit fuses, using the battery negative fuse as the neg reference I get a neg voltage at the individual ckt fuse. I would think the output should be a positive 12vdc. This would explain my lack of house power. Has anyone experienced this, any thoughts on the cause
Hi alumi-naught; How can you have a negative voltage in DC current? You may have a reversed polarity but not negative voltage. Voltage is a positive pressure, not negative. If your Voltmeter reads Voltage, then the polarity is correct. Available amperage in those wires can be sufficient just enough for the Voltmeter to read Voltage. This however does not mean that you have sufficient available amperage to run your circuits.
In some cases there is a 50 amp fuse in the system on the negative side to double protect your 12 Volt system from shorts coming from shorted or reversed polarity on your 110 UniVolt circuit,through common ground. If this fuse is blown you can only pick up the negative connection through a turned on circuit such as light bulb which is insufficient to provide enough amperage to your panel. Load test the 12 Volt input to your panel, you may have a loose or weak connection there. You can test for integrity of the circuit with a Amp meter hooked in line of a positive lead while connected to battery and applying a known amperage draw load to the end of that circuit. Plug in something of known amperage draw such as 12 Volt coffee pot. If you observe same reading on amp meter as the specified draw at the end of the circuit the wire is good for the amount of that amperage.
Please bear in mind that a bad negative connection produces same results as bad positive connection which amounts to a incomplete circuit. Voltage is the level of pressure, Amperage is Volume. Volume [amperage] is needed to make things work. Thanks and good luck. Need further help PM me. " Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-10-2006, 07:15 AM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
locate your 12 volt fuse box, the glass fuses, find the largest fuse there, it'll probably be on the top and check to see of this fuse is blown. Replace it and you will have have power. Did you happen to start your gen set with the shore power connected? That is how I blew this fuse.
Chaplain Kent
Forest River Forester 2501TS
Chaplain Kent is offline   Reply With Quote
Old 12-10-2006, 07:14 PM   #6
Found it Thanks to Boatdoc you got me thinking. Turns out it was a high resistance connection at the load side of the positive 50 amp fuse holder where it connects to the positive buss bar.
I used the spare 50 amp fuse located right above the bad one as a temp measure until I can locate a new fuse panel (some of the other fuse holders are a little suspect). Thanks for all your suggestions.
Mark
Old 12-10-2006, 07:21 PM   #7
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Yea
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
house batteries wb13798 Mechanics Corner - Engines, Transmission & More... 16 02-07-2006 07:41 PM
power boosters John Our Community 18 11-19-2002 03:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
no power Mike Electrical - Systems, Generators, Batteries & Solar 10 08-20-2002 06:38 PM
