Old 09-10-2007, 06:32 PM   #1
1991 35' Airstream 350
Windsor , North Carolina
Steps
Well, the inevitable (given my usual level of foresight) has happened. I left the steps down (I think that they are 2 step kwikee's) and bent them (this, at least, I did really well) yesterday. Popped a rivet.
Does anyone know if the risers (the metal bars on the sides that hinge up/down) on these steps are steel, or aluminum? The rivets that attach them to the steps and to the plate are universally aluminum, and there is a composition washer as a spacer between.
My tool box didn't have a magnet in it--tonight.
Best,
R
ralley is offline   Reply With Quote
Old 09-10-2007, 06:47 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
When I was up to the Mother Ship a couple weeks ago noticed they have all kinds of step parts if you have to replace.
Sorry to hear of your misfortune....
Old 09-10-2007, 07:04 PM   #3
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Steel or Aluminum
There are steel or aluminum.
The parts are available from Airstream or Inland maybe others as well.
I would not take a chance on a bolt shearing and a hip injury.
R
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 09-11-2007, 12:18 PM   #4
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Our Kwikie 2 steps are all steel. We just put the unit in last year.
Rob
Robfike is offline   Reply With Quote
Old 09-11-2007, 07:04 PM   #5
Ralley,
Don't feel alone here. I did the same thing with our previous SOB. I was readying the motorhome for a week long trip to start later that day and pulled away from our shop and hit a stump with the steps. I had to use a come-a-long to pull them back into a reasonable semblance of straight.
Very embarrassing to say the least
bkahler is online now   Reply With Quote
Old 09-11-2007, 08:59 PM   #6
1989 34.5' Airstream 345
Silverton , Colorado
I posted this on another forum site, but will paste to here...
Step relocation and increasing sputters...
[quote=ArStrm345LE] nice post. I actually would be interested to hear your techique.
Initially, it was really basic...first, I explored new combinations of old epithets. Then, I pulled forward over the stump I had backed over(though not reccomended, this is an effective way to remove old stumps...Kinda like removing a bad tooth when you were a kid). Then, I got out and went to the hot tub. about a week later, I drilled out all the rivet bolts, hammered the braces flat(sorta), took a long bar to the braces coming out of the motor housing, installed bolts, prayed to the Great Aluminum One, and flipped the switch. Nothing happened...till I remembered to turn the chassis battery switch back on. The step is about 3/4 inch out of kilter(gives it that 'homey' look), and checking the bolts is now part of my ever-expanding maintenance routine. I opted for regular bolts, as there are more stumps and other things out there, and I'm almost on a first-name basis with Murphy.
The unit has started to sputter more, so i will be replacing the rear fuel filter, again...someday, I suppose I will have to flush the tank, but for now, replacing the fuel filter is so much easier. I replaced the fuel pump with the spare that came with the unit, then found out it wasn't the pump...anyone with this problem should learn from me that testing the existing fuel pump is an obvious diagnostic tool that doesn't require removal...
mike
Michael & Tracy
1989 345 Motorhome
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 09-12-2007, 04:36 AM   #7
[quote=ScrapIrony-2]I posted this on another forum site, but will paste to here...
I wouldn't exactly call it a technique! If I remember correctly the steps never did get used again after that. I didn't have time for repairs before the trip and so we started using a little stool to get in/out of the motorhome. When pulling it back into position with the come-a-long things got bent more and a couple of welds broke. My main goal was to be able to retract the steps so we could leave. We sold the SOB and ended up buying out 1984 310. Fortunately it has good steps.....for now
Old 09-12-2007, 06:11 AM   #8
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
We just had our Kwikee steps installed by a dealer and there is an override switch which brings the steps in when I forget and turn on the ignition. I was there for the installation and the installer wrestled with this feature for quite some time since our diesel ignition switch is different than a gasser ignition. He got it working and I am glad he did since I am known to drive away with Chummy plugged in , levelers up, and awning out.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 09-12-2007, 06:56 AM   #9
tn2
DixieDove
tn2's Avatar
1978 Argosy 27
1978 28' Argosy 28
Camden , Tennessee
Steps
I come from the aviation industry and I am beginning to think that with everything hanging out of RVs....ie...awnings...leveling jacks....steps...antennas....vent covers....etc... and along with us older RVer's depleting memory cells....Maybe it's time to start using a check list like pilots do ( or are suppose to). Nothing worse than to be driving down the highway....15 miles from the campsite....and say....Did I put the toilet drain hose back in the container or might I be dragging it down the highway. Ya know.....there's no way to first take that look around you to see if anyone wittnessed your dumb act....then act as if I MEANT to leave that thingamajing out.
Isn't RVing FUN
tn2... Bad thing about doing nothing is you never know when you're done.
tn2 is offline   Reply With Quote
Old 09-12-2007, 09:42 AM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The Airstream manual for our unit has a sample checklist in it - I thought it was quaint - maybe a better idea than first thought.
Old 09-12-2007, 09:58 AM   #11
I have a bright orange index card taped to the dash with "DRAWERS CLOSED?
STEPS UP?"...cheesy, but so much cheaper than the alternate...I suspect that I will be adding to the list as the cranial cell numbers dwindle. I would really like to have one of those switches in the door frame...the PO (or someone) removed the original, apparently with a grinder, but was thoughtful enough to put silver duct tape over the hole. We have an annoying alarm for when I forget to lock the door, and I hate it, but I haven't driven off with the door open, yet...
mike
Michael & Tracy
1989 345 Motorhome
Old 09-12-2007, 07:13 PM   #12
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Lest y'all feel bad ...
Some time ago I had to back out of a wooded parking place. Taking up the approved position (head out window, neck twisted around to see backwards) I backed up ... not seeing the open bathroom window and extended driver side awning. Needless to say, they encountered a tree trunk almost immediately, with awesome consequences. Moral: Murphy is most definitely alive and well.
Empathetically,
Jamie
jking is offline   Reply With Quote
Old 09-12-2007, 07:42 PM   #13
I don't feel bad, just adequately ignorant...mike
Michael & Tracy
1989 345 Motorhome
Old 09-13-2007, 07:13 AM   #14
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Checklists are only as good as the pilot using them. I for one will admit to going through the checklist and having the big fan turning up front. When I release the brake nothing happened. A little more power, ...wonder if the brakes are stuck?..... then as I popped up over the chocks I knew what I had forgotten. At least I had remembered to untie the little C150 from the tiedowns.
I had out of wack steps and went to the local Wal-Mart parking lot that was left abandoned by Wal-Mart when they moved to the new super center outside of town. They have these big congrete bollards up close to the doors that will allow you to anchor to the steps with a come-a-long. From there you can exert all the force required to fix some of the more minor alignment issues. Now as far as really mangled units it's sometimes nessesary to remove the unit or replace with new.....
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
New Steps Chaplain Kent Classic Motorhomes 1 08-16-2007 08:44 AM
Steps Cap-N-Red 2001 Safari 11 06-07-2006 05:47 AM
Steps Devoman Steps 3 12-16-2005 08:44 PM
steps lmbando Steps 18 03-25-2003 08:30 PM
Steps Texas Steps 6 10-31-2002 10:50 PM
