Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 09-11-2007, 09:39 AM   #1
1985 34.5' Airstream 345
Fishers , Indiana
Step Door Jam Switch Needed
Does anyone know where to get a new Door Jam Button Switch that controls the steps for a 345 MH. This switch allows the steps to lower if you open the door with the key on. It is located in the door jam between the middle and lower hinge. I have sourced a number of places and have not yet found one to fit the opening. Any help is appreciated.
Wayne Olson is offline   Reply With Quote
Old 09-11-2007, 10:07 AM   #2
Naples , Florida
Wayne,
Chances are that you have 'Kwikie' steps in your rig. You need the reed switch that controls the step activation. You can call Kwikie Products directly at 1-800-736-9961, tell them your problem and have them send you the new part.
lewster
Old 09-11-2007, 12:28 PM   #3
Fishers , Indiana
Thanks for your help. I went on Kwikee.com and found what I think is the correct switch part number 905328000. I will confirm after installation and testing. Thanks again.
Old 09-11-2007, 06:57 PM   #4
Wayne, if the switch you listed above doesn't work check with Andy at Inlandrv. I got the correct door switch for our 310 from them a few months back.
1975 24' Argosy Motor Home
Old 08-10-2014, 03:03 PM   #5
1986 34.5' Airstream 345
Knoxville , Tennessee
Did you find and get your part? If so can you post exact part number and site you got it at? In need of the same thing.
Thanks in advance,
Garry
Docseuss is offline   Reply With Quote
Old 08-14-2014, 04:11 PM   #6
Found this guide which may help some folks out there with their Kwikee steps. http://www.rvtechlibrary.com/exterio...svc_manual.pdf
Lower door step TomW Steps 33 02-17-2022 03:17 AM
Door Step tn2 Argosy Motorhomes 2 06-21-2007 03:21 PM
door step geezernbabe Steps 11 02-16-2007 09:31 AM
Door-Step Cycle -345 winner General Motorhome Topics 8 10-04-2002 02:19 PM
Door Step Pick Steps 0 06-17-2002 09:05 PM
