The wheel was supplied by the manufacture of the chassis. The same year from any of their trucks should fit. That a trip to a junk yard 79 may be out of stock from a dealer.
If the 79 steering wheel is anything like the steering wheel in our 74 Argosy then the one Mike is referring to is different. The Classic coaches (1980 & later?) appeared to use some sort of adapter on the steering column and a Moto Lita (or similar) steering wheel was used. The 74 Argosy motorhome used a standard Chevy truck steering wheel.
I've been searching for a replacement for our 84 310 because the leather is torn pretty bad but haven't found a replacement source as yet.
__________________ "Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
My wheel is not GM but something else...leather outer (cracked and flaking) with alum spokes and an Airstream center....hope I can find an aftermkt wheel that will accept the AS logo center...anyone have any luck with this problem???thanks for all the feedback...joe
This picture isn't from our motorhome, I snagged this picture off of eBay a while back. However our steering wheel is identical except for the missing chunks of leather, etc .
I think the wheel was made by Moto Lita. In checking out their website Moto-Lita, the Classic British Steering Wheel I couldn't find a steering wheel that was the right diameter. Ours is about 16" in diameter and in leather they didn't show one that looked like ours in that size.
They do custom wheels as well and I wouldn't be surprised if Airstream had them made special.
The search continues.........
Thanks Brad for the research. The Kit Car Mark 4 looks a lot like mine but the largest is 15" and as you noted ours is 16". I would go for the 15' if the 9 holes for attaching fit the pattern of mine. Could use the 1" addl space for my lap....joe
If that is the wheel, it is pretty much an aftermarket wheel. You may be able to just go to an Autozone, or other DIY auto parts store and get one. Even JC Whitney should have them.
Terry Change is inevitable, except from a vending machine
AIR#2611
