Old 12-30-2015, 12:04 AM   #1
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Spartan Chassis dash heater help
Can anyone give me some ideas...my dash heat ti not working. When I turn it on with the dash control, I know the valves are open because the pipes are warm in the on position, and the fans work, but no hot air is coming out of the dash. I can see what I think is the AC evaporator under the passenger footwell, but I can't see the heater core.
Thanks for ideas.
SebasSF is offline   Reply With Quote
Old 12-30-2015, 12:10 AM   #2
SebasSF's Avatar
It's cold here in California!
Name:	ImageUploadedByAirstream Forums1451459438.499257.jpg
Old 12-30-2015, 03:29 AM   #3
Long Island , New York
[Duplicate thread]
OTRA15 is online now   Reply With Quote
Old 12-30-2015, 03:32 AM   #4
1995 36' Classic 36
Ludington , Michigan
The control cable has a tendency to jump off the lever in the control head. You can manually move it from the heater box.
Kota is offline   Reply With Quote
Old 12-30-2015, 05:11 PM   #5
Rivet Slave
1995 36' Classic 36
Crossfield , Alberta
Heater core location
The heater core is located on the upper left (passengers) side inside the hood It was manufactured by Acme. The plastic shroud has to come off to expose it. Takes a good hour to remove the core. The trickiest part of removal were the bottom shroud screws. On my 95 it had a removable access panel to get at them . Not sure if my 94 has the same access panel.
Good luck
Gou0001 is offline   Reply With Quote
Old 05-29-2016, 10:11 PM   #6
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
SebasSF Did you ever figure this out? I found my heater control valve needed to be replaced. It's the same one on our rig as it is on my excursion. You can get it from autozone or any other car parts place. Just ensure you get the $13.99 one and tell them the excursion does not have an auxilliary system (single pass through with no branching)
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-30-2016, 09:40 PM   #7
SebasSF's Avatar
Hey Vycan, I have not got this figured out yet, so thanks for the thoughts. Are you referring to the one in line in the water hose?
Old 05-31-2016, 03:28 AM   #8
Vycan's Avatar
Manhattan , Kansas
SebasSF. Correct, the one on the hose.
Old 06-02-2016, 09:36 PM   #9
SebasSF's Avatar
One thing I did check was if the hose was hot on both sides of the valve then it was open, and it was so I figured the valve was working. I did find some troubleshooting advice in the manual that I will follow before it gets cold out here again.
Old 06-02-2016, 09:52 PM   #10
Vycan's Avatar
Manhattan , Kansas
That just leaves your heater door control. It should also be vacuum operated.
Old 06-03-2016, 04:38 AM   #11
1995 36' Classic 36
The control head has a POS connection block for the vacuum lines. Good place to check for leaks. The vent right above it pops out and gives access with small fingers. The control cable often pops off the control leaver due to poor routing of the cable. Is the vacuum pump working?
1995 Airstream Classic 36 Diesel Pusher Class A Motorhome RV Spartan Chassis eBay Watch Airstreams on eBay 0 02-18-2014 06:20 PM
1995 Airstream Classic 36' Diesel Pusher Class A Motorhome RV Spartan Chassis eBay Watch Airstreams on eBay 0 02-11-2014 12:50 PM
1995 Airstream Classic 36 Diesel Pusher Class A Motorhome RV Spartan Chassis eBay Watch Airstreams on eBay 0 01-25-2014 10:30 AM
Spartan Mansion 33 :: 1950 Airstream Spartan Mansion j2m Airstream Registry Discussions 0 01-28-2012 09:38 AM
Heater, Airconditionor Dash Control cooperhawk Airstream Motorhome Forums 4 11-11-2003 08:38 PM
