Old 12-27-2014, 10:06 AM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Sparky's advice needed.
I'm pretty sure I have the original converter in place now. I'm looking to upgrade my converter and maybe add a sine wave inverter as well after reading somewhere that they are prone to fires. I would also want a charger for the batteries that was intelligent and not over charge them. I'm also not looking at going solar just yet as my generator was recently replaced and is still good.
During the subfloor replacement in the rear I did upgrade my electrical wiring to the transfer switch to 50 amp (two hots, one neutral and a ground wire). I replaced the 30 amp circuit box to a 50 amp square D but since I haven't changed the 30 amp transfer switch yet I'm still in 30 amp mode with one hot no connected and the other feeding both bars in my circuit box.
What systems are you running and specifically what products did you buy? Also how hard was it to install?
Cheers and Happy New year.
Tony
ID:	229296   Click image for larger version
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 12-27-2014, 12:37 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
This was the response that I got from bestconverter.com in 2011:
The PowerMax Boondocker is our most popular and its a great unit. Also comes with a 3 year warranty. Probably the 60 amp model with a pair of batteries would be perfect.
Powermax Boondocker Converters
I ended up buying the recommended unit. Installation was snap because my USAF trained son did it for me (he said that it was easy). It has worked fine since, much quieter that the original.
Waipio Rim is offline   Reply With Quote
Old 12-27-2014, 02:02 PM   #3
1995 36' Classic 36
Ludington , Michigan
http://www.amazon.com/Progressive-Dy...ower+converter
I swapped out the old DC supply with this one. I'm happy with it so far. The old one only put out about 12.6 volts. Trickle charge at best. The new one will boost charge allowing you to charge the batteries pretty quickly from the generator or shore power. Full A/C load on it with 60 amps out is only about the same as a blow drier. I can plug it in at storage with my 20 amp adaptor cord. The charge wizard boost charges, and maintains the batteries quite nicely.
Kota is offline   Reply With Quote
Old 12-27-2014, 03:25 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I also bought the 9260. Easy install, works great.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-27-2014, 04:12 PM   #5
1982 28' Airstream 280
Redwood City , California
I also installed the 9260 a couple yrs ago. It works great.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 12-28-2014, 12:30 AM   #6
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
So why didn't you gents take the time to add an inverter/charger when you installed the 9260?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 12-28-2014, 01:44 AM   #7
lewster's Avatar
Naples, FL , Hood River, OR
I'm with Vycan!
A Magnum MS-2012 is a 2000 watt pure sine wave inverter with a 100 amp fully programmable battery charger system. Fully programmable means that you set it for the type of battery (which sets the charging voltages), size of the battery bank (which sets the absorption phase duration) and other important features. It is also fully temperature compensated. NO CONVERTER offers you these features or this level of quality battery charging!
Also, if your are running 50 amp service, the MS-2012 has the capacity to operate your entire breaker box, as it has 2 hot inputs and 2 hot outputs rated at 30 amps each for a 60 amp total capacity with automatic pass-thru transfer switching when on shore/generator power. The ME-RC remote gives you all the pertinent visual information needed to see exactly what the inverter is doing.
These units are engineered and constructed in the USA and are also fully field serviceable (unlike most converters and other inverters that are made in China and are throw away units) and carry a 3 year warranty.
PM me if you would like more detailed information about the MS-2012.
Old 12-28-2014, 10:28 AM   #8
1995 36' Classic 36
Originally Posted by lewster View Post
I'm with Vycan!
$1700 is a bit of an investment.
http://www.solar-electric.com/maenms...FapDMgod4m0Alw
I have a $300 watt inverter that I can plug into one of the cigaret lighters if I need AC for something. I don't bother feeding the coach ac system with the inverter.
Most everything is DC. No ac only looses the roof ac and the microwave. 2000 watts won't run any of that.
Old 12-28-2014, 11:01 AM   #9
1995 36' Classic 36
Make that 300 watt.
Old 12-28-2014, 11:38 AM   #10
lewster's Avatar
Just for clarification, the Magnum MS-2012 WILL provide sufficient power to operate ANY microwave. Of course, the size and condition of your batteries is just as important as the size of your inverter.
And just for the record, I have installed 8 of these Magnums in Airstream trailers this year, so there ARE folks who are willing to pay for the features that they offer.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 12-28-2014, 02:42 PM   #11
1995 36' Classic 36
The microwave/convection oven draws about 2000 watts. If the inverter is 100% efficient it would have to draw about 160 amps from the 12 volt batteries.
Just want to make sure people understand the practical limitations of batteries and inverters in this application.
Old 12-28-2014, 02:45 PM   #12
I actually have the big Zantrex inverter but I doubt that I will ever install it in the MH. My dad had it sitting in the garage. It works great. I have it installed on my flat trailer and used it at Burning Man.
I don't really need an inverter and for me it would just be overkill, your mileage may very LOL. However it would raise the "cool" factor of the airstream a bit!
In all seriousness, I looked at installing it in place of a new converter. Bottom line is there is no space in my 280 to put it! Also I wouldn't bother without installing additional batteries, again no place in the 280 to put extra batteries.
Then comes the cost factor. Not economical for my situation even with my free labor. The cost of rewiring and cost of additional batteries wouldn't be worth it's minimal use. My dad had already hard wired a small inverter by the table in the salon area and it has served its purpose of plugging in a cell phone charger a time or two when all the 12 volt outlets were already in use.
It takes a lot of effort to manage one's battery power when boondocking and adding the additional battery draw wouldn't make it easier.
I also go by the philosophy that my MH is there to be used. When it came time to replace the original converter and the not original batteries, the intent was to get the mh usable and on the road as quickly as possible. I think the wiser choice for me was the PD which is working flawlessly!
Help this non sparky Sirvan69 Batteries, Univolts, Converters & Inverters 7 11-17-2013 01:10 PM
Sparky :: 1967 Airstream Safari Mel Airstream Registry Discussions 0 08-19-2011 08:30 AM
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
