Old 06-06-2012, 03:22 PM   #15
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
I placed weatherstripping close to the top on the inside of the aluminum front to keep water from running down the side of the motorhome and on top of the slide compartment. There was already plenty of caulking between the aluminum front and the plastic cover of the compartment. There are no water lines at that location; the compartment is directly below the dining table and benches. I will be going camping for the first time next week so I will see if I still get an accumulation of water in this compartment since I will be getting into this compartment more often.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 06-06-2012, 03:59 PM   #16
The point I am trying to make is you need LESS caulk at that point so that it forms a gutter, and runs away.
They were overfilled at the factory, and it negated the whole design!
I knew I had a pic showing better what I was trying to explain...
Here it is...
Blue line is what happens, putting water ON the plasic lid.
Red is what should happen..
Old 06-07-2012, 06:05 AM   #17
Gunter
gunner's Avatar
Greenville , Ohio
I understand what you are saying, I will check again and modify if I find it not to my satisfaction and is not similiar to yours.
Gunter
