Old 06-24-2013, 12:02 PM   #1
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
Side marker lights
I have been looking for the side marker lights for my 85 32.5 but I can't seem to find the same light. Dose anyone know which light Airstream used i.e Chev, Ford, or Dodge and what years. Or was it an after market light
ID:	189189   Click image for larger version
shepherd57 is offline   Reply With Quote
Old 06-24-2013, 01:08 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you are doing a "Restoration: consider LEDs. They are brighter and use far less power.
Grote LED Clearance and Marker Lights
2004 Excursion 4x4
Old 06-24-2013, 08:56 PM   #3
John,
I've not seen that style of light before. Guess I need to look at the 310 and see if it has that type.
Also, I sent you an email the other day and haven't heard back. Just wondering if you received it.
Old 06-26-2013, 03:52 PM   #4
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
Our '86 345 has the same side marker lights.
I think they may just be a generic truck unit.
Robfike is offline   Reply With Quote
Old 06-28-2013, 04:58 PM   #5
shepherd57's Avatar
Lindsay , Ontario
I have looked everywhere and I can't seem to find them ,I thought maybe someone had replaced theirs and had a part number.
Old 06-28-2013, 06:00 PM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Change them all to retro tear drop shaped LEDs.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-28-2013, 06:05 PM   #7
John,
Would this light work? It appears to be an LED version of the original style.
LED version?
I'll keep looking to see if I can come up with anything else.
Old 06-28-2013, 09:41 PM   #8
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 38
When we had a NAPA store, I purchased all mine new from them. I put in LED bulbs. All outside lights are LED except for the head lights.
NAPA AUTO PARTS
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (267,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 06-28-2013, 11:32 PM   #9
m.hony's Avatar
2013 30' Classic
You could get HIDs for the headlights...
TAC #MS-10
Airforums #70955
Old 06-29-2013, 09:51 AM   #10
cmadmaxman's Avatar
Images: 38
The headlights have not gone without upgrades .
I have installed relays for both high and low, along with heavy wiring. New replaceable light, light housings, with much brighter bulbs. When on high, not much goes unseen when all four lights are on .
Have thought of HID's, and everything is in place to go that direction if I want now.
AIR Member 12654
1982 310 MoHo
Old 06-29-2013, 07:17 PM   #11
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
Not sure if this will help with your question but, I do know the front turn signal lense is a GM part. I took my lense to two different GM dealer parts counters. Both told me that it was not a GM part. I eventually found a very tiny almost unnoticeable number that I Googled and found it was turn signal lense for a chevy truck. I got a replacement from gmpartsdirect.com.
Gregsch is online now   Reply With Quote
Old 06-29-2013, 09:02 PM   #12
shepherd57's Avatar
Lindsay , Ontario
Yes the front signal lights are from a 1967-68 Chev pickup
Old 06-29-2013, 09:06 PM   #13
shepherd57's Avatar
Lindsay , Ontario
Thanks Cmadmaxman that looks like the exact one I hope they have them in red also. All of mine are in tough shape
Old 06-29-2013, 09:11 PM   #14
cmadmaxman's Avatar
Images: 38
I purchased mine from Mill Supply Inc. They sell for all makes of step vans GM P30 etc. They sell the lens or complete assembly. Here is the link for the lens below.
Parking Light Lens Only GM Chassis Stepvans
I also found this part number from GM Parts Direct. A little less money if it is the right part.
http://catalog.gmpartsdirect.co/oemp...6/5959160.html
AIR Member 12654
1982 310 MoHo
Old 06-29-2013, 09:13 PM   #15
cmadmaxman's Avatar
Images: 38
Yes they have em in red as well .
AIR Member 12654
1982 310 MoHo
Old 06-29-2013, 09:19 PM   #16
shepherd57's Avatar
Lindsay , Ontario
Do you happen to remember how much it was for those lights
Old 06-29-2013, 09:40 PM   #17
cmadmaxman's Avatar
Images: 38
Here in the states it is only $4.76 plus tax. Hope you have NAPA up there.
Here is the link for the red ones: http://www.napaonline.com/Catalog/Ca...00R_0218619496
AIR Member 12654
1982 310 MoHo
Old 06-29-2013, 10:13 PM   #18
shepherd57's Avatar
Lindsay , Ontario
We have Napa here but the prices are usually double some times more. I will check next week
Old 06-30-2013, 06:47 AM   #19
John,
If you have trouble sourcing them let me know and I'll get some for you.
Old 06-30-2013, 08:08 PM   #20
shepherd57's Avatar
Lindsay , Ontario
Thanks Brad I will check it out on Tuesday and let you know
