Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 07-01-2009, 02:15 PM   #1
Argosy 20
Profile:  1973 Argosy 20
Del Mar-San Diego N. County Coastline , California
Shower Pan Support Question???
I have noticed that there seems to be no support for the fiberglass shower pan on my 1977 Argosy MH? The PO knows nothing about this as he never used the shower/bath, but I am wondering if I am missing some type of important support piece?? Any insight appreciated.
jbsails is offline   Reply With Quote
Old 07-04-2009, 01:57 PM   #2
Profile:  Richmond , Kentucky
Can you give us a little more detail? What floor plan is your motorhome? Are you referring to bottom support, side support, or ?
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 07-04-2009, 11:37 PM   #3
Argosy 20
Shower Pan Follow Up
Thanks Brad...the Argosy is a 24 with the rear bath and the shower/tub is on the curb side. There does not seem to be any support under the shower/bath floor at all under the coach. I am wondering what you all have or see under your models?
Best,
JB
Old 07-05-2009, 06:41 AM   #4
bullydogsmom's Avatar
Profile:  1972 25' Tradewind
old mystic , Connecticut
Do yo have the shower pan out or does it flex when yu step into it? Ours flexed real bad, turns out that the floor was totally rotted under it. Ours isn't a MH but could be same problem.
Annette
bullydogsmom is offline   Reply With Quote
Old 07-05-2009, 07:15 AM   #5
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
My model has a plywood platform about 3-4 inches high.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 07-08-2009, 02:58 PM   #6
Our 20' Argosy motorhome with side bath has a little bit of flex where the drain goes into the tank. Other than that it feels pretty solid.
I would bet there might be problems with the plywood subfloor being rotted out under your bathroom.
Old 10-24-2009, 02:14 PM   #7
Profile:  Jamestown , Kentucky
My 89 345 is Very Soft under the bathtub floor and flexes the most at the area of the drain. I suspect rotten plywood sub flooring from seepage around the drain, so far ! To scared to look further as I do not need a new ??? Project at this time !!!
John Haggard is offline   Reply With Quote
Old 10-24-2009, 05:55 PM   #8
Minno's Avatar
Lexington , Minnesota
If the plywood subfloor is good and solid, but the shower floor flexes when you stand in it, then maybe this fix I used in a SOB trailer years ago will help. I filled the cavity underneath the shower pan with great stuff foam. Once it hardened, the shower pan was very solid.
Chris
Old 10-24-2009, 06:58 PM   #9
Chris
I hope that is all I need Minno !
How did you spray it under there ? from underneath ?
Or from the top ?
The Hallway floor is solid as well as all other flooring as far as I can tell !
Old 10-25-2009, 08:10 AM   #10
Minno's Avatar
I used the access hatch that was located in the side by the plumbing. It was an access hatch for the drain trap, so it was low and under the shower pan. I attached a piece of vinyl tubing (1/4” I think) over the tube that comes with the can, and used duct tape to seal them together. I also used some duct tape to attach the long tube to a stick so I could get it way back under the shower pan. Then I foamed it, starting at the back and working my way out to the access hatch.
Put paper down on the floor in front of the shower access panel, and mask off around the panel. And wear gloves. The duct tape didn’t make a 100% leak proof seal, but it worked well enough for what I was doing. Black electrical tape might work a tad better for taping the tubes together.
Good luck!
Chris
Old 10-25-2009, 08:21 AM   #11
Good luck!
Chris
Thank You Minno! sounds like you thought this through !!
Old 10-25-2009, 10:59 AM   #12
3 Dog Nite's Avatar
Profile:  1974 25' Tradewind
Cleveland , Tennessee
This sounds like a great fix for my problem too. Thanks a lot Minno. Did you use the regular Great Stuff in the red can or the Great Stuff for minimal expansion in the blue can? I'll tackle this when I change out the gold drain basket. I like killing two stoned birds with one throw like this.
Ricky
I know the voices in my head aren't real, but some of them have pretty good ideas.
AIR 22749
1974 25' Tradewind - no TV yet
1989 345 LE Classic Motorhome
Courtesy Parking; 20 amp, water, dump, wifi
'tween exits 27 & 33, I-75
3 Dog Nite is offline   Reply With Quote
Old 10-25-2009, 12:09 PM   #13
Minno's Avatar
This was pre- minimal expanding foam days, so it was the regular expandable Great Stuff foam. I think that gets harder, anyway, than the minimal expanding stuff you can get now too.
Two stoned birds are much easier to hit with one throw, aren't they?
Cheers,
Chris
Old 10-26-2009, 02:05 AM   #14
Profile:  Silverton , Colorado
I know in our '89, the subfloor is that particle board that crumbles after a bit of extended moisture...we've been lucky, so far but if we lose our luck, plywood is in the future, as is the epoxy sealant...mike
Michael & Tracy
1989 345 Motorhome
Visit our blog http://www.scrapirony.com/
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Custom Shower Pan Tom Bray Sinks, Showers & Toilets 19 04-29-2009 07:28 PM
Shower pan removal? glacierrunne Sinks, Showers & Toilets 2 07-02-2006 10:45 PM
Anyone curious about what's under the shower pan? SafeHarbor 1978- 1979 Excella 500 0 01-28-2006 03:05 PM
64 Bambi II shower pan Pat McSween Sinks, Showers & Toilets 2 08-02-2003 03:53 PM
Need photo of drain pan support Lexxy 1966 - 1968 Safari 3 05-04-2003 02:53 PM
