Old 09-22-2017, 07:16 PM   #1
Roddyy's Avatar
1982 28' Airstream 280
Grantsburg , Wisconsin
Shower faucet
In my 1982 Excella, I need to replace the shower faucet. I am having trouble locating one that will allow me to adjust the spray volume as well as the temperature. Can anyone point me in the right direction? Thanks.
Roddyy is offline   Reply With Quote
Old 09-22-2017, 11:20 PM   #2
Smartstream's Avatar
Port Angeles , Washington
I use a conventional mixing valve and this shower head. http://www.campingworld.com/shopping...d-nickel/68323 You can close it down to a trickle while you soap up and control the flow while you rinse off. It really feels like a lot more water than you are actually using.
Cheers, Dan
~ Margaret Thatcher ~
Old 09-22-2017, 11:43 PM   #3
1979 23' Safari
Wayland , New York
What kind is there now? Is it hot and cold knobs going to a diverter. Mine I have to adjust the volume at the shower head.
Shower head like this.
https://www.etrailer.com/RV-Showers-and-Tubs/Ultra-Faucets/277-000047.html?feed=npn&gclid=EAIaIQobChMI2bmExb661gI VhIWzCh058gKVEAQYBSABEgK5lPD_BwE
Little knob slides to control volume. Others are available with similar function.
This is what my 79 had originally,
https://www.etrailer.com/Accessories-and-Parts/Phoenix-Faucets/PF223701.html?feed=npn&gclid=EAIaIQobChMIpoHNjr-61gIV1o2zCh36gAo2EAQYASABEgK_DvD_BwE
In the one I'm restoring its getting a shower valve with single lever temperature and volume control. The plumbing is so different it wouldn't be possible to switch without doing a total re plumbing.
Shower Dribbles ... Faucet and Toilet flow great Killo1 Fresh Water Systems 3 03-18-2007 09:54 PM
Shower faucet Philip Williams Sinks, Showers & Toilets 11 02-09-2007 07:55 PM
Shower faucet replacement racoco 1974 - 1979 Sovereign 6 10-30-2006 03:38 PM
Shower faucet repacement gergstuff All Argosy Trailers 4 08-02-2006 12:41 PM
Shower Faucet wa3vez Mechanics Corner - Engines, Transmission & More... 2 08-30-2004 03:39 PM
