Old 12-30-2012, 06:16 PM   #29
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Dakota,
As much as I tend to prefer the retro look of the earlier Classics, THAT is the power set up that makes me drool. Maybe someday. What kind of 1/4 mile times are you seeing at the track?
streamquest is offline   Reply With Quote
Old 12-30-2012, 08:51 PM   #30
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Originally Posted by jm2 View Post
OK, I'll bite - what did you buy, and what are your second thoughts about?
thanks!
Sorry I only gave half an answer. I got a Spectre 728 intake, see: http://www.summitracing.com/parts/sp...FSTZQgodRmkA6w
Assuming that I can actually pull off installing it, I am having second thoughts about disconnecting and trashing what seems to be a functional smog system. After driving the 310 from coast to coast and getting something worked on at pretty much every stop along the way, it is running better than ever. I am keeping the intake under the couch for now, maybe when something breaks it will get a chance.
Waipio Rim is offline   Reply With Quote
Old 01-20-2013, 08:17 PM   #31
Here's a picture of my engine compartment. Plenty of room to work on things
Old 01-20-2013, 08:45 PM   #32
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Attachment 177097
you are a brave man.....
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-20-2013, 08:51 PM   #33
I don't know that "brave" would be the word most people would use to describe me
Old 01-20-2013, 09:15 PM   #34
I was called "Mis-guided" once.... or twice...
Old 01-20-2013, 10:03 PM   #35
1989 34.5' Airstream 345
Silverton , Colorado
Brad,
does that loose wire bother you...?
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 01-20-2013, 11:28 PM   #36
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Nothing that a little Rustoleum can take care of!
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 01-21-2013, 07:19 AM   #37
Originally Posted by ScrapIrony-2 View Post
Brad,
Which one?
Old 01-21-2013, 07:20 AM   #38
I should buy stock in Rustoleum, I seem to always be using lots of it!
Before the motor goes back in the engine compartment will be a nice shiny black. Have to wait until I get a warmer day so I can steam clean it. After that the paint goes on.
Old 01-21-2013, 05:39 PM   #39
1936 20' Clipper
1947 22' Liner
Curtis Wright
Brad,
Have you considered painting with POR-15? It's a bit pricey, but the finish you end up with is amazingly hard and very glossy, and it loves to be applied over a rusty surface. (Not to imply that you might even have any rust ). As I understand it, Rustoleum is nothing but plain old spray paint with a great marketing campaign.
Charly
Old 01-22-2013, 06:19 AM   #40
Charly, actually I usually use a product called Miracle Paint in applications like this. It's basically the same as POR-15 only it has some UV inhibitors. I've been using it since 1996 and have been very pleased with the results. At times I will top coat it with Rustoleum but not always.
As far as rust on the Argosy, I did spot some the other day that I probably should take care of
Thanks!
Old 01-22-2013, 11:05 AM   #41
1995 36' Classic 36
Ludington , Michigan
Have you considered white? Makes it easier to inspect and work on.
Kota is offline   Reply With Quote
Old 01-22-2013, 01:48 PM   #42
You're definitely right about white making it easier to see things. I saw an argosy mh in Pasadena that had the engine compartment and front wheel wells painted a light gray. Sort of made things stand out.
Miracle Paint only comes in gloss black and silver. Maybe using silver top coated with gray would look pretty good.
I'll have to think on this for a while.
Thanks for the feed back!
