Old 12-16-2012, 05:20 PM   #15
1974 Argosy 20
Kooskia , Idaho
Glass in doghouse cover
Here are two photos my friend sent me showing the glass in his 1974 GMC motorhome doghouse cover, along with his comments.
"Second one was from the rear. First one from driver's seat. I could not get the glare off but I doubt they want to see the fuel injection bonnet or my aluminum intake anyway. I need to do a little maintenance on it soon. We are going to change the carpet in the cabin area and will change and insulate the cover then. One would think there would be a lot of heat through the 1/4 inch tempered glass but not bad. We can always throw a blanket over it if we need to. I will say that it has saved us two fires. My wife keeps a better eye on it than I do."
Name:	100_0768 (Medium).JPG
ID:	174759   Click image for larger version
Name:	100_0767 (Medium).JPG
Old 12-16-2012, 05:43 PM   #16
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Now that is an idea that needs more development.
What about a double glass in a skylight type frame that lifts up for access?
If you are going to fancy up that engine compartment, you want to enjoy the money you spent.
Another thought would be, to install recessed cup holders to keep that coffee hot while running that 454.
With the glass top, you can watch the potatoes bake on the manifold.
Dave
Old 12-25-2012, 10:41 AM   #17
Silver Bullet
choctawmel's Avatar
1986 34.5' Airstream 345
choctaw , Oklahoma
You can see it?
How about now?
choctawmel is offline   Reply With Quote
Old 12-25-2012, 03:11 PM   #18
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Wow, talk about a tight fit!
When I had my headers put in, they bent the oil tube so be careful with that.
Show us again from the dog house once you get it all in place.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 12-25-2012, 05:25 PM   #19
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Would really like to learn about the aluminum intake your friend used? Am wanting to ditch the factory filter housing & snorkel for something that will feed cooler and better filtered air into the carb.
Thanks in advance....
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 12-25-2012, 06:25 PM   #20
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
"Would really like to learn about the aluminum intake your friend used? Am wanting to ditch the factory filter housing & snorkel for something that will feed cooler and better filtered air into the carb."
This thread: http://www.airforums.com/forums/f159...ers-62717.html
has information on a couple of different cold air intake setups. It inspired me to buy something similar that I may have talked myself out of installing.
Waipio Rim is offline   Reply With Quote
Old 12-25-2012, 06:32 PM   #21
1974 Argosy 20
Kooskia , Idaho
jm2: I sent you a private email with the friend's information so you can contact him directly about what he did and used. Remember, his is an Olds 455, not a Chev 454. They are quite different engines.
Old 12-25-2012, 06:43 PM   #22
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
Thank you, Rob! And, Merry Christmas!
Joseph & Gabrielle
Old 12-30-2012, 03:04 PM   #23
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Cummins 6BTA
Here is a picture of the cummins 6BTA in our 1991 350. Needs some cleaning and paint to make it pretty. So you can consider this the "before". May be years till I get an "after" For some reason the DW thinks we need to work on the making the inside nice before the engine compartment?? What?
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 12-30-2012, 04:15 PM   #24
Visually the engine compartment looks to be the same size.
Old 12-30-2012, 04:57 PM   #25
wxbuoy's Avatar
Brad,
It is approximately: 33" fore to aft, 29.5" side to side.
Dave and Felicia
Old 12-30-2012, 05:31 PM   #26
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
Originally Posted by Waipio Rim View Post
This thread: http://www.airforums.com/forums/f159...ers-62717.html has information on a couple of different cold air intake setups. It inspired me to buy something similar that I may have talked myself out of installing.
OK, I'll bite - what did you buy, and what are your second thoughts about?
thanks!
Joseph & Gabrielle
Old 12-30-2012, 06:05 PM   #27
1995 36' Classic 36
Ludington , Michigan
Here's one of my backwards mounted mattress heater.
Kota is online now   Reply With Quote
Old 12-30-2012, 06:11 PM   #28
wxbuoy's Avatar
Attachment 175594
Very nice! I read your thread about the banks installation. Quite impressive. I wish I could through a mattress over mine to deaden the turbo. Looks like I have to go out and spend the $$ for the low density foam to redue the doag house rather than just get a good mattress.
Dave and Felicia
