Old 10-12-2010, 10:09 AM   #1
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Shock Absorbers (Bilstein)
Wow, I'm amazed at how difficult it seems to be to find the current model # and someone who has them in stock. Anyone know what the correct (up-to-date) model # is for the Front and Back Bilstein shocks on a 1995 Classic Pusher 36? My repairman said the numbers he was given by Bilstein for the FRONT are AK-1240 and the BACK are AK-1241 but anyone I call with those numbers can't seem to pull them up on a computer. ARGH!
GREENovaters is offline   Reply With Quote
Old 10-12-2010, 10:38 AM   #2
1989 32' Excella
Limestone , Alabama
Below is a link to the Bilstein motorhome shock application guide - I didn't see a listing for an AK-1240 or AK-1241. For an Isuzu motorhome chassis there is a listing for AK-1250 front, AK-1251. That is the only "AK" number listing I saw...
http://www.bilsteinus.com/Bil_Mtrhm_apps6-10.pdf
war eagle is offline   Reply With Quote
Old 10-12-2010, 07:35 PM   #3
Registered User
1995 36' Classic 36
Images: 14
Thanks War Eagle! Yep, the part number I listed earlier was incorrect and your sheet shows the correct one! I found out late this afternoon what the right part # was and got it ordered from Truck Parts and Accessories for Pickup Trucks, Medium Duty Trucks, Semis, and RVs - TruckSpring.com!
Old 10-14-2010, 07:50 PM   #4
AirRowan's Avatar
1986 34.5' Airstream 345
Key West , Florida
I have an 86 345 and the shocks have helper springs is that Original Equipment from Airstream or just something a PO added? I would like to buy Bistein shocks but do not want to lose any spring in the front end. The PO added spring nuts (helpers) because the bags wore both dead I replaced them now and the front is much better but it sways and bounces to much.
I also have weird wear on the front tires there are 4 rows of treads the second one in from the out side are worn down 3/16 more then the outer ones. I run 75psi in front and 55psi in rear My local goodyear tire man thinks it is just the bands in the tires.
AirRowan is offline   Reply With Quote
Old 10-30-2010, 08:42 PM   #5
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
I run 75 in the front and 85 in the back. The manual tells you to have the front air bags at 55lbs. I think 55 is to low for the back. I am a newbe, but this has worked great for me.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 11-02-2010, 05:32 AM   #6
Robfike's Avatar
Speedway , Indiana
78# in the front, 77# in the rear duals, and 72# in the tags works for our 345. See my thread on finding the ideal pressure for each tire by checking the temp.
The air bags in front should be 55#. The rear bags are taken care of by the rear compressor.
Rob
Robfike is offline   Reply With Quote
Old 11-02-2010, 05:51 PM   #7
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Thumbs up Shock Absorbers
Roger Robfike. I run 75 PSI front and rear with 55 PSI in the airbags in the front. Compressor takes care of the rear airbags. When replacing shocks, you need to keep in mind that the shock keeps the tire firmly planted on the road, and assists in braking action, it does not lift the chassis. By having good shocks you minimize tire wear and have shorter stopping distance. A very important suspension component indeed.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 11-02-2010, 06:34 PM   #8
Robfike's Avatar
Speedway , Indiana
Here is an example of how good the Bilstein shocks are. This the apex and exit of turn 10 at the Putnam Park Road Course. We are not going very fast...but you get the idea.
Photo www.photomotiononline.com
Name:	Putnam Airstream 015.jpg
ID:	114334   Click image for larger version
Old 11-15-2010, 06:27 PM   #9
TOG Unit Member
1979 31' Excella 500
1995 36' Classic 36
Marietta , Georgia
Greenovators, Can you state the model number (front and rear) of Bilstein's, please?
BudClem is offline   Reply With Quote
Old 11-15-2010, 07:50 PM   #10
Registered User
1995 36' Classic 36
Images: 14
BudClem - I'll find out tomorrow what numbers they are and post them for you.
bilstein, classic, pusher, shocks
Delco shock absorbers TomW Shocks 13 06-20-2016 11:48 PM
Shock Absorbers jfowler218 Shocks 14 12-07-2010 06:36 PM
Do I need to add shock absorbers? AlbertF Shocks 3 10-19-2006 05:25 AM
Shock Absorbers for 62 Overlander Silverfly Shocks 6 07-14-2004 01:18 PM
Shock absorbers changing gary 1970-79 Tradewind 8 03-10-2004 06:15 PM
