Old 09-22-2012, 02:07 PM   #1
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
seatbelts?????
I do love duct tape/gaffers tape, and I have no doubt that should an accident occur my two girls would stay put if I taped them to the couch, but they're hoping for an easier solution.
Our 310 has no seatbelts for the rear passengers. A previous owner pulled out the two buckets in front behind the passengers seat, placed sound deadening material on the floor and recarpeted. All that's there now is two armchairs that are not fastened to the floor (think about what's going to happen when they start to fly). The couch behind the driver has no seatbelts either. The 345 we looked at had them for the couch.
Where can we get a set and how difficult would they be to install?
Thanks again for the help.
Old 09-22-2012, 02:30 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
They should be available at almost any auto parts store. If not, any auto salvage yard should have bunches of them. I remember the belts were attached at the floor, on each rear mounting bolt where it goes from the seat into the floor. you may have to try a stud finder to locate the metal pieces under all the new stuff.
Old 09-22-2012, 03:17 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
The chairs behind the passenger seat never had seat belts, but the couch did. Check in the roadside fold-out to see if the belts are still there, or at least, the connections.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-22-2012, 03:54 PM   #4
1982 28' Airstream 280
Redwood City , California
Same here, found mine under the couch, between the wall and the water tank. I leave them under the coach and tell others sorry I can't take you with on the trip because I don't have seatbelts for you!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-22-2012, 04:29 PM   #5
Well Preserved
1993 21' Sovereign
I have seen those barrel chairs with seat belts, they usually are attached where the pedestal is bolted to the floor. Whether OEM, or aftermarket installed, I can't tell you. As a rule, though, if the chair can't be locked in one position (ie, swivels with no way to keep it from swiveling), it should not be used for travel.
BTW, Mike, how is Bess doing?
Old 09-22-2012, 04:33 PM   #6
I still have the original decals above my barrel chairs...
Old 09-22-2012, 05:06 PM   #7
Well Preserved
1993 21' Sovereign
And no seat belts there, right?
Old 09-22-2012, 05:13 PM   #8
Correct.
Old 09-22-2012, 05:25 PM   #9
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Seat belts under the street side lounge
Our 82 24' MH has two seat belts fastened to the floor under the streetside lounge behind the drivers seat. Don't think I would have know that if we hadn't taken the lounge out to be reupholstered. Girls need seat belts.....boys too for that matter and dogs maybe as well.....don't want a 53 pound projectile dog coming forward....we are going to install a place to restrain our dog comfortably......just haven't decided where yet. paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 09-22-2012, 05:28 PM   #10
Dazed and Confused
Isuzusweet's Avatar
I remembered looking at the road side storage and not seeing the belts which were very apparent in the 345 we had seen as they were attached at the bottom of the storage. That is not to say that they are not there. They maybe folded up in the bottom of the couch some where? I will check when I get her home.
Thanks guys
PS I have a WIX number for the oil filter of 51282 but I'm not 100% on Wix. The stock Isuzu number is 1-13240161-0????
Old 09-22-2012, 05:53 PM   #11
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
I've got a set of seatbelts on both dining seats. Not too familiar with your floorplan, but if you have dinette, look there as well. Both of my barrel chairs have seatbelts, the belts are attached at bottom of chair with a very sturdy looking metal bar.
Good Luck, Derek
Old 09-22-2012, 06:48 PM   #12
Well Preserved
1993 21' Sovereign
Paula, four anchors in the floor with two straps to hold a crate on the floor should be more than enough. I can snap a few pictures of the anchors and straps Monday when I get to work.
Old 09-22-2012, 08:28 PM   #13
Smartstream's Avatar
Port Angeles , Washington
Thanks guys
Check out this site Oil Filters Revealed - MiniMopar Resources
It gives a lot of good info on filters. Wix makes filters for NAPA and Carquest and have made excellent filters for years. Also they are much easier to find than the Isuzu filter which is probably made by one of the major filter companies, maybe even Wix.
The Barrel chairs mentioned by Crazyvw in the 34.4 are mounted on a rigid base with a locking swivel like the driver an passenger chairs and the belts are bolted to the bar which is bolted to the base which is bolted to the floor. If anybody is interested I have 2 extra bases.
On my coach the front seat bases and seat belts are bolted to the steel tube cross members under the floor, not just through the floor.
Cheers, Dan
Old 09-23-2012, 09:24 PM   #14
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Ours had three sets behind the couch (I found them a year after owning and using the coach). They were all in bad shape so I replaced them with new belts from JC Whitney. Now we have belts in the couch and dinette.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
