Old 08-28-2011, 04:55 PM   #1
Bethany533's Avatar
1983 30' Airstream 300
Covington , Louisiana
Sealant for water heater
I will be installing my new water heater later in the week and have a question regarding what type of sealant to use. I've read through some of the old posts and I'm not sure what type to get. I know that silicone based sealants are a big NO. As long as I use a polyurethane based sealant does it matter which brand? I know I need a no-sag type since it will be on a vertical surface. Am I correct in my thinking?
I've looked for the Vulkem and Sikaflex locally and cannot find it (New Orleans area). Many of the posts mentioned Fastenal but when I go to their website, they don't have either product. Any suggestions would be greatly appreciated.
Bethany533 is offline   Reply With Quote
Old 08-28-2011, 05:10 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I used the jTempro 636 (vulkem) ordered from one of the onling suppliers. worked well.
Old 08-28-2011, 05:17 PM   #3
x
XXXX , XXXX
Bethany you want to use either a putty tape or even better a butyl tape. Both are available from any RV dealer. The as a secondary seal use Vulkem. Vulkem is no longer used as a brand name.
10.1 oz Aluminum Tremco TPV626 300 mLC 1-Part Polyurethane Textured Masonry | Fastenal
wasagachris is offline   Reply With Quote
Old 08-28-2011, 05:42 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I used Tempro 636 as well. Fastenal has it. I have had zero leaks around the heater.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 07:02 PM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Basic h/w heater question (empty tank) TennisMan Water Heaters, Filters & Pumps 4 03-01-2011 02:19 PM
