Team,
Would like to pick your brains again on some scoop ideas for two areas on the classic.
1. Scoop for the
intake
2. Scoop for the
engine compartment similar to those found on old planes
I am considering these options of scoops, so if any of my theories are off, please comment and correct me.
Scoop for intake:
With the rear mounted engine the intake is on the side, but the tail of the motorhome begins to taper just forward of the intake. Expecting a negative dynamic pressure influencing it, and adding the scoop to enhance air flow. So, besides aesthetic appeal/destruction depending on your view, would there be any gain to having a scoop to increase dynamic pressure at the intake? I ask because I suspect the turbo would make up for this. I would additionally expect issues with regard to precipitation in foul weather, and reinforcing the intake box to prevent air escaping places I would not want. Essentially I see this one as the little to no gain.
Scoop for engine compartment:
Essentially create a scoop forward of the rear axle, that is 4" tall, and extends across the width of the coach. The scoop would have two tapper points to a 5" orifice just inside the frame above each frame rail. Ducting would terminate one orifice just forward of the exhaust manifold with a shaped nozzle to assist air cooling of the manifold at speed. The other duct would terminate forward of the engine on the injector pump side to force more air across engine. The thought I had is the air would additionally assist in cooling the engine by forcing more air across the radiator/trans cooler/intercooler. Another thought would be to alter the fan shroud and plug the two ducts into it at either side. Both ducts would have an a vertical "s" curve to deal with precipitation, and a hole drilled at the low points with a rear facing scoop for drainage.
End state: cooler engine compartment temperatures, to assist with efficiency of Th/Tc. I would expect to see an increase in efficiency although minor at about 1-3%, and most likely in the 1% area.
