Old 10-17-2013, 06:42 PM   #1
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
running lights?
I have had a leak (probably several) above the drivers seat and the passenger seat ever since I bought this MoHo. I decided to check the marker lights for leaks and maybe convert the lamps to the new LED fixtures while I am at it. I took the first one apart tonight. I think I found part of the problem. There is a 1/2" diameter hole with a wire that goes to a bolt that looks to me like it does nothing. Does anyone else have this arrangement? If so what does it do? It looks like the 1/2" hole was sealed with a big wad of caulk that has long since failed. Can I simply push the wire back into the body and seal the opening with a patch?
ID:	198149   Click image for larger version
ID:	198151   Click image for larger version
Gregsch is offline   Reply With Quote
Old 10-17-2013, 06:56 PM   #2
1974 Argosy 20
Kooskia , Idaho
The wire to the bolt is most likely the ground (-) wire for the marker light and you will need to have it or something like it to make the lights work.
Old 10-24-2013, 08:58 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yeah you have to love AS quality sometimes...... This is what I found under both my corner marker lamps.
Mine has a power wire attached to a terminal on the marker lamp (mine were converted to LED by a PO). The ground for the lamp is provided by the screws holding the fixture on. I filled all the holes with sikiflex 221 (or Tempro 635) and remembered to dab a bit of sealant under the mounting screw heads.
Old 10-24-2013, 11:02 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Many marker light fixtures are connected to the common/ground with one of the mounting screws. Take note: there is usually a brass grommet in one of the mounting holes, which is attached to the bulb base in one way or another.
The skin of the trailer provides the return path, common/ground for all of the 12 volt DC devices, both inside and outside the coach.
Old 11-01-2013, 06:08 PM   #5
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
maybe I'm just not that familiar with 12v DC systems, but can aluminum be a 'ground'?
Old 11-01-2013, 06:27 PM   #6
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
why, yes.
iirc, among non-precious metals, aluminum comes after copper and before brass in electrical conductivity.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 11-01-2013, 06:34 PM   #7
crazeevw's Avatar
See, I DO learn something new every day! Thanks jm2
Old 11-01-2013, 06:46 PM   #8
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
just as we learn from your many adventures, Derek!
Joseph & Gabrielle
Old 11-01-2013, 07:15 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It has nothing to do with aluminum being common/ground.
The steel frame of the trailer is also part of the common/ground plane. The negative wire in the UCord is connected to the steel frame of the trailer in most cases. As is the negative side of the battery in the TV.
Just as the steel or aluminum components of the TV are part of the electrical circuit on a 12 volt DC system.
In reality the negative side of the 12 volt DC circuit is not GROUNDED. It is simply the COMMON side of the 12 volt DC circuit. There by the return path for most DC devices is the metal in the trailer. It saves wire and it saves weight by literally cutting the amount of wire used in half.
The only true ground in the trailer is provided by one of two sources. You either drive a ground rod (which by the National Electric Code must be a rod 8' long made of a specific material) into the ground at your site. Or you connect the shore power cord ( properly wired) to a properly wired power source. In the latter case the utility company in effect has driven the ground rod for you.
The use of the term GROUND should have never been used for the COMMON side of a DC circuit. IMHO
