I printed the info but of course the Moho is at the storage yard. I will try to get by soon to get the info. We just upgraded our hitch to 10000# also. Debbie
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
Try going to McMaster-Carr. Search "Light Bulbs". Although I couldn't find your specific model number on Mcmaster or Google I'm sure you can find a suitable replacement. They have one of the best selection of bulbs I've ever seen with a really user friendly internet user face.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Debbie,
Can you post some pictures of your hitch upgrade?
Thanks!
__________________ "Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Thanks Srt8strm. K&H must be the ones that took over Sparton Mfg. They have the same unit we have only it is now black.
I have found a bulb at Camper Repair 205-665-2531. Sonny is the owner.
I will also be contacting K&H to keep a spare in stock.
Rob
Will send a pic when we see the moho again, they welded a 2"x6" plate right at the rear of the coach............after seeing Rob's upgrade we expected to see a long tube running forward on the coach but the owner said they have been doing the heavy duty plate for quite a while. Cost was $650, I think the same as Robs.
AIR 7992
Interesting. There are so many different ways to strengthen the hitch. I'm sure you'll be happy you did!
I really wanted to strengthen ours the way Rob's was but couldn't find the tube at the time I was doing the work. So I substituted by using a heavy piece of channel and some angle. I got by cheaper because I did all the fabrication myself and then paid a friend who is a certified welder to weld the areas that I was not comfortable doing.
Streamers,
I replaced my spot/flood bulb. The actual part number of the bulb is
"GE 4700". I don't use it much, but I like having everything working as it should.
Rob
