Old 08-30-2012, 07:54 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Roof marker light quandry.
Everything else works fine, except the center front. I'm getting this reading after replacing the bulbs. Don't pile on, the probe color on the ground is red because I don't have a black ground probe. Do I have a ground problem in the housing?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-31-2012, 04:38 AM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Mike, the problem is definitely that red probe....
what do you read when you swap your test leads?
seriously now, how do your voltage readings across the battery, and from + battery to ground compare with your readings at the marker lite? are they in the range of 13.2?
given that everything else works fine except the center front, test with the new bulbs out. if your voltage reading is OK, then there's a bad bulb.
if the voltage between the + lamp supply and the housing ground is that low, that looks like a bad ground,
however, if the voltage between the + lamp supply and another good ground anywhere else on the vehicle is that low, then I'd suspect that you have a bad connection on the supply side.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 08-31-2012, 06:34 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Test a working light too, so you have a known good value for comparison.
Chris
Old 08-31-2012, 09:25 AM   #4
Mike Leary's Avatar
Images: 11
Thanks for the great suggestions, will clean all the fittings and test again. Would not even attempt this without the use of my orchard ladder, as it's the hardest place to reach on the coach. Wish I could travel with it without looking like some rig out of "The Grapes of Wrath."
Old 08-31-2012, 12:02 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Thanks for the picture of the orchard ladder, give me an idea on how to fix my ladder problem at home. I have a 10ft stepladder but in front of MH it is not stable to sterech from upper rungs to marker lights, mounting hinged diagonal or wide foot supports should do it.
Old 09-01-2012, 05:08 AM   #6
1989 34.5' Airstream 345
Silverton , Colorado
I bit the bullet and paid about $200 for a telescoping ladder...$2.50 for a 'noodle' from wallyworld as a cushion for the ladder contact...it has served me well...old carpet and plywood allow me to work the top without my dainty figure dimpling the skin...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 09-01-2012, 03:55 PM   #7
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Trying to keep all the bulbs working is why I put LED's on ours. One of the problems that we have on these, the steel screws and Vulcum sealer will keep you from a good ground. The light unit is grounded to the housing, and the housing needs to get ground from the skin. I replaced all the rusty steel screws with Stainless Steel and took all the housings off and re-sealed. With the LED's, problems gone!
With all that being said, my best guess would be you have a ground problem.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 09-03-2012, 05:59 PM   #8
crazeevw's Avatar
Saint Petersburg , Florida
Mike,
Where in the world do you store your orchard ladder going down the road? I've about decided one of the telescoping ladders is the way to go, but now you've made me re-think....
Thanks, Derek
Old 09-03-2012, 06:53 PM   #9
ladder day saints...?
Originally Posted by crazeevw View Post
Mike,
Thanks, Derek
I really think the telescoping ladder is a BIG plus...kinda pricey($200?), but I have had mine for about 4 years, and while it's a hassle to move front(nights) to back(days), it has been an invaluable tool for me(and others)...a foam 'noodle', cut and split, will provide the scratch protection, and the storage becomes mostly a pick-it-up-put-it-down problem for some of the older folks. Weighs about 40-45 pounds, and the most damage you can do to yourself is collapsing it on your fingers, straining your back, or falling off...all of these are avoidable with simple exercises in basic intelligence...if you need instructions, I have learned them all...sometimes twice...ok...ok...ALL of them at least twice...still, unless you have a roof rack and stairwell, the telescope is a serious consideration. I have had two short step stools for windshield cleaning...I'm not going to run over a third one...
BTW, noodles are really handy in many ways...cut and split them for your windshield wipers while parked for awhile...cut and split for the awning bars so you only get a bump, not a gash...decorate your awning tie downs and avoid those embarassing 'rope' burns...useful, cheap, and user-friendly...m
Michael & Tracy
1989 345 Motorhome
Old 09-04-2012, 10:46 AM   #10
Getting to that area over the windshield is tricky, and safety is important!
I have a folding telescoping ladder... this one...
Here is what I was doing...
And, I forgot to take a pic!
I unfolded it and extended it to the max... I put two thick movers blankets down... One on the header triple folded and one on the windshield under the ladder, and laid the ladder to follow the front slope of the screen... Nothing was touching the glass!
Then I wrapped a rope around the a lower rung and around the two front overiders, so the ladder could not slide out!
Hope that makes sense...
BE SAFE!
Old 09-04-2012, 04:41 PM   #11
Mike Leary's Avatar
Images: 11
Mike,
Thanks, Derek
We don't travel with the orchard; I don't mind the clearcoat starting to fail or the dents (I've done by myself), but I draw the line on tacky.
Old 09-09-2012, 03:58 PM   #12
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
its refreshing to see that Airstream did make improvement over the years like adding the ground wire, instead of relying on the chassis ground. Or was it just the different fixture in fashion that year...? Either way those were bad designs, completely melted and falling apart when touching them.
May as well replace all 5 in the rear now, there is no changing bulbs on this set-up
ID:	167849   Click image for larger version
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-09-2012, 05:22 PM   #13
Mike Leary's Avatar
Images: 11
Yup, your pics show a REAL ground wire! Wow, what a concept.
Old 09-09-2012, 05:57 PM   #14
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
This won't work if you need it while on the road, but I have a 6 to 9' plank with the ladders at home base which comes in very handy for work on the front of the Clipper. For those Classic with the slope back windshield you probably need the 8 to 13' to get close to the front marker lights.
I carry a 12' collapsable ladder that my old wool work socks tie onto for finish protection.
Dave
