Old 10-07-2014, 05:39 PM   #1
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Rivet Shaver
Ok,
So I'm out working on Airstream over the weekend, see that my center beltline black plastic is taking a beating in the Florida sun. So, I decide to pull it off, and count how many Olypic Rivets I'll need in order to remove beltline. Close to 200 rivets! Of course, at dining windows, I've got rivets about every 2 inches. Someone must've been practicing at Jackson Center that day.
Anyhow, here's my question. Has anyone purchased a rivet shaver? Found this one on eBay, but since I have NO idea what to buy, or what to look for, can anyone tell me if this is sufficient?
Avro Raptor Avro XT250RS Rivet Shaver 20 000 RPM | eBay
Or should I go for the gold and drop $ on this one?
Rivet Shaver | eBay
Would I be wasting my money on either?
While I'm at it, anyone know what size Olympic Rivet I need?
http://www.vintagetrailersupply.com/..._p/vts-179.htm
Thanks for any help or information anyone can provide.
Derek
Old 10-07-2014, 05:45 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
You don't necessarily need to buy a special rivet shaver 'gun'. You can find a rivet shaver that attaches to your drill/driver at VTS...and other places. But it is pricey...for sure.
arktos55343 is offline   Reply With Quote
Old 10-07-2014, 05:57 PM   #3
crazeevw's Avatar
arktoss55343, I've got several rivets to shave on roof now, been trying my hand with Dremel and failing miserably. Figure before I have to go back and replace those rivets, I'd better pop for something better, especially if I'm going to have to shave almost 200 to eliminate the center beltline....
Derek
Old 10-07-2014, 06:04 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Well, I did over 300 rivets today. It was with the VTS purchased shaver.
Old 10-07-2014, 06:29 PM   #5
1972 25' Tradewind
Hopkins , Minnesota
The Dremel is hard to control...tho I've used it in a pinch. As MR suggests, the VTS shaver works pretty well.
Old 10-07-2014, 07:13 PM   #6
aquinob's Avatar
Portsmouth , Virginia
The issue with rivet shavers other than the one sold by VTS is the cutter bit itself. It is a concave profile that follows the head of the rivet. The only place I have seen the replacement cutter bit is VTS and they want about 145 bucks for just the bit. Most aircraft rivet shavers are flat cut bits designed to produce a flush cut rivet head. A while back I picked up a Dotco brand pneumatic shaver for about 75 bucks thinking I could find a suitable bit. Being the cheapskate I am, I never sprung for the special but but ended up with a straight bit that I paid around 6 bucks for. I used it to replace the water inlet on my 74 Overlander and was satisfied with the results. Here are some pics to show what I'm talking about:
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 10-08-2014, 04:06 AM   #7
crazeevw's Avatar
aquinob,
Thanks so much for the reply. I appreciate everyone's reply, I was trying to stay away from a $225 purchase from VTS. I can afford the less than $100 for rivet shaver, can't quite justify over $200 though.
Thanks again, Derek
Old 10-08-2014, 04:16 AM   #8
Baltimore , Maryland
Do yourself a huge favor and buy the shaver. Use it then sell it to someone else here. You could pass it on for 70% of your original purchase. Unfortunately, you will use it and not want to get rid of it once you have it.
Old 10-08-2014, 05:34 AM   #9
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
I'm in the market for a rivet shaver as well. Just curious, how often does the bit need changed? Does it hold an edge or wear quickly? Thanks!
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 10-08-2014, 06:41 AM   #10
1988 25' Excella
Trumbull , Connecticut
Rivit Shaver
The blades on my rivet shaver are carbide. I bought mine used from a dealer who was closing up shop about 25 years ago. I use it connected to an electric drill. I have used it on over a 1000 rivits as I had to remove all the rivits on the drivers side of my Excella after a dealler replaced both upper and lower panels on the damaged side but I had many water leaks after to contend with. Bought the olympic rivits from Bialer Rivit Co some where in TX and over time replaced all the dealer installed rivits, then I had no more leaks. The shaver is still as good as new but wouldn't part with it.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 10-09-2014, 10:37 PM   #11
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Derek,
You'll never regret investing in a quality tool. Buy the real thing, and use it once. A big smile will appear on your face, you'll be glad you bought it, you'll find a bunch of other things to do with it, and you'll never want to part with it. The end result is even more impressive when you put a little polish on those rivet heads.
Charly
streamquest is offline   Reply With Quote
Old 10-10-2014, 06:47 AM   #12
Indiana, PA
TAC PA-5
WBCCI 4871
After using our shavers for 25 years, they still shave the Olympic rivet heads as good today as they did 25 years ago.
Cheap tools don't last long, but are good enough for small jobs.
More expensive tools, do their job, over a long long time.
Like they say, you get what you pay for.
Old 10-10-2014, 07:22 PM   #13
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
here is an oldie:
http://www.airforums.com/forums/f381...lation-23.html
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-14-2014, 04:24 PM   #14
crazeevw's Avatar
Ok, what started out as a cheapie 'throw-away' rivet shaver on eBay, by the time bidding had ended, along with shipping, the cheapie was now over $70. Decided that I'll just save my pennies, and go ahead and make the plunge and head over to Vintage Trailer Supply and buy a proper rivet shaver. Don't look for completed shaved rivets for a while though.....lol
Thanks for the advice, Derek
How durable is a Cyclo polisher? What about a rivet shaver? Andy R Cleaning, Stripping & Polishing 13 09-13-2011 05:56 AM
Ebay rivet shaver TomW Ribs, Skins & Rivets 4 02-26-2004 01:54 PM
Rivet Shaver To buy or Rent???? srgntpepper Ribs, Skins & Rivets 6 10-06-2003 06:18 PM
Rivet Shaver Bfrank Airstream Motorhome Forums 5 05-10-2003 02:46 AM
