Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 05-23-2017, 08:21 PM   #1
1986 34.5' Airstream 345
Londonderry , New Hampshire
Rivet in front side windows?
I noticed a small rivet in the front sliding glass windows on both sides.
A hole is drilled through the glass at the rear edge for the rivet. It
seems to serve no purpose. What could it be for?
Pete.
Air345Fly is offline   Reply With Quote
Old 05-24-2017, 12:12 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Pete.
The glass is the same as used in the early model MH which had a different latching system (using a spring plunger) into that hole....when the latches changed in 1977 Airstream had to fill the hole with something so why not a rivet? Well I can think of several reasons why not a rivet (like it interferes with the glass seating into the side channel and must have been a pain to install) but when did Airstream actually ever think through a problem rather than simply grab the first solution that was to hand?
http://www.airforums.com/forums/f310...ml#post1950335
martin300662 is offline   Reply With Quote
Old 05-24-2017, 06:06 AM   #3
Thanks, I knew that there had to be an explanation.
Pete.
Front Side Windows Classic - Vertical lip install noiva Classic Motorhomes 39 08-22-2018 05:17 PM
Jack shell from front/back or side/side? SkatiePower Repairing/Replacing Floor &/or Frame 4 01-31-2017 08:23 AM
Pair of "Wing Windows" Front Side Windows fotochop Airstream Classifieds 0 11-23-2014 10:35 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
help on front side windows Zeppelinium Windows & Screens 8 05-23-2006 11:22 AM
