Old 10-16-2013, 04:24 PM   #15
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
And underneath the pink foam I found this......
Check out the black mold on the 1/4" sub floor piece leaning up against the wall.
ID:	198061   Click image for larger version
Old 10-16-2013, 04:26 PM   #16
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Keep up the good work, it looks great. I love the trap door idea in post 6 for the fuel tank connections. Hope I never have to do it. Maybe I'll just keep your number on speed dial.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 10-16-2013, 04:30 PM   #17
Dazed and Confused
Isuzusweet's Avatar
On the passenger side a PO built a drywall wall out of pressure treated 2x4" with an oak top and a folding table.........On the other side of the drywall I found.....
Check out the bolt which leads to the lowest bolt for the door hinge.
Yes that is the bottom aluminum sheet that you can see in pic 2. The floor is rotted out on both sides to the aluminum under layer.
ID:	198063   Click image for larger version
Old 10-16-2013, 04:37 PM   #18
Dazed and Confused
Isuzusweet's Avatar
So at the end of the second day of demo I have passenger channel cleared out, sink cabinet out, and both wall panels out. I had to cut the drivers side wall panel to get it out but the sink cabinet will cover the cut line...once I build a new one that is.
The grey on the 5/8" main floor is leveling cement provided by who ever did all this work in the first place.
The brownish area is completely soaked in water. The black smears coming from the other side is as far as the water got from the door side.
The main floor is not coming out in pieces........it's coming out in bits. As my friend stated...."It's not a floor.....it's compost".
ID:	198066   Click image for larger version
Old 10-16-2013, 07:04 PM   #19
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
"Keep up the good work, it looks great. I love the trap door idea in post 6 for the fuel tank connections. Hope I never have to do it. Maybe I'll just keep your number on speed dial."
DITTO!!!!!
I can't thank you enough for this! I need to do a small section in the cockpit by the passengers seat. This thread makes it so much less intimidating!!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 10-17-2013, 05:17 AM   #20
Dazed and Confused
Isuzusweet's Avatar
DITTO!!!!!
LOL I am getting rather good at this. Just remember to use materials like the Coosa or Starbright boards so you DON"T have to do it again, EVER. This is one job I'm doing my best to put myself out of business doing.
Yes I'm not sure what's going on under the seats. A PO put the same rubber sheets up there as well. The problem is the rubber. It may deaden sound, but it trapped all the moisture.
Old 10-17-2013, 02:57 PM   #21
Dazed and Confused
Isuzusweet's Avatar
Day three demo. Ran saw cuts with a Skill saw set just deep enough to almost score the aluminum bottom sheet. To aid in prying the piece up make your saw cut just before a nail line. If you cut after the nail line it will be a beatch to pry up. Use a grinder to cut off the heads of the nails that are left.
Wonder if anyone can guess what's in pic 2.
ID:	198116   Click image for larger version
Old 10-17-2013, 03:02 PM   #22
Dazed and Confused
Isuzusweet's Avatar
I think I found my seat belt anchor holes??????
Finally the demo is done. I did take out some but not all the bolts. I decided to leave the lag bolts in below the storage doors on the drivers side but took all the rest out. I left two in on the passenger side but will cut just before placing new flooring in.
ID:	198118   Click image for larger version
Old 10-17-2013, 03:09 PM   #23
Dazed and Confused
Isuzusweet's Avatar
I figure that I have pulled out well over 200 lbs of extra flooring, water soaked plywood and three big garbage bins of bits and pieces. The lower piece in the pic is a very rotted piece. The top piece was the final piece I pulled out, close to the door, so yes a bit of black but not too bad.
The black plastic tube in pic 2 is A/C drain tube???? It is crimped shut as they riveted the inside sheet over the tube pressing it against the C channel. I wonder if this would account for the water?
ID:	198120   Click image for larger version
Old 10-17-2013, 05:45 PM   #24
wxbuoy's Avatar
I think that is exactly what happened! Amazing that it was finally found after all these years (and all the damage it caused!)
Dave and Felicia
Old 10-26-2013, 03:43 PM   #25
Dazed and Confused
Isuzusweet's Avatar
The new floor is in and the drivers/passenger side is just fine....after all the layers I had to take off to get to the original floor.
ID:	198764   Click image for larger version
Old 10-27-2013, 03:08 AM   #26
wxbuoy's Avatar
Does anyone know where to get Coosa and Starbright boards in the U.S.? I can get may hands on marine plywood rather easily.
Dave and Felicia
Old 10-28-2013, 04:03 PM   #27
Dazed and Confused
Isuzusweet's Avatar
If you can get your hands on Marine board easily, you should be able to order Coosa board easier than I was able too. The only distributor in Eastern and Central Canada was an outfit in Halifax, Nova Scotia; which is about a 2000 kms away from me. I was lucky to phone the right Marine shop in my area and they shipped three 3/4" 4x8 boards to me without any shipping tacked on.
I went with Coosa over Starboard as it's a lot lighter than Starboard and the expansion rate with Starboard makes it tricky to use as flooring.
There is a distributor in Florida but contact Coosa LLC for a closer one to you. Phone the closest Marina or boat sales and service place.
Cheers
Tony
Old 10-28-2013, 04:59 PM   #28
wxbuoy's Avatar
Thanks Tony!!
Dave and Felicia
