Old 01-07-2009, 04:38 PM   #1
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
Question Replacing Flooring
We are considering ripping out the p/o choice of carpeting and replacing it with cork flooring. We have a source of 5/32" pure cork prefinished tiles (polyurethane coating) at $1.29/sq.ft. Has anyone any experience with glueing cork flooring down on the A/S plywood subfloor? Thanks for sharing your expertise. Jamie
jking is offline   Reply With Quote
Old 01-07-2009, 04:58 PM   #2
Images: 59
I haven't any experience with glue down, but I would recommend staped down underlayment under the cork. It would be a smoother finish, and you could easily remove it later if necessary.
markdoane is online now   Reply With Quote
Old 01-07-2009, 05:41 PM   #3
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
Can you share your source? That's a terific price. I wanted to put it in my Silver Princss but jus too expensive.
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 01-08-2009, 11:22 AM   #4
1989 34.5' Airstream 345
Silverton , Colorado
Daisy would be a great source for info, as she did that, and then sealed it with some coats of poly...she's often on the VAL digest...
mike
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 01-12-2009, 07:07 AM   #5
Jamie
jking's Avatar
1984 31' Limited
Danalee - and others who might be interested: That price was quoted on Lumber Liquidators: Hardwood Flooring for Less! for what they called "London Cork Tile". It is only 4mm thick and definitely requires an underlayment (which they'll sell you for $50 a roll). If you pursue this please keep me posted on the job progress.
Jamie
Old 04-20-2009, 07:49 PM   #6
Santa Cruz , California
Images: 12
We have just finished this process in our 83 310 motorhome, with much more expensive cork laminate -- a central core of some homosote-like material, cork on the bottom and some sort of cork composite with a dozen layers of urethane film bonded to it in manufacture. Comes in planks about 36 x 12 inches that click together. I used Regupol-QT underlayment which is made of recycled rubber. The results are very nice -- probably quieter than with the carpet, surprisingly enough. We redid the carpet in the bedroom too and the last step is to get another piece of carpet cut and seamed to provide a non-slip surface over the cork when such is wanted. But the cork is beautiful.
The underlayment is (sparsely) stapled to the floor, the cork is entirely floating, no glue. Same approach I used years ago putting Pergo in an Airstream trailer.
dljosephson is offline   Reply With Quote
Which Flooring???? AndyPenny Floor Finishes 29 09-18-2008 03:26 PM
Flooring arjo Repairing/Replacing Floor &/or Frame 19 04-28-2008 05:57 AM
need new flooring ? bigghpappa4 Floor Finishes 3 08-11-2006 10:41 PM
Ideas for replacing flooring for Minuet with aluminum composite floor pattyo Repairing/Replacing Floor &/or Frame 6 06-24-2006 08:56 PM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 07:59 AM
