Old 03-29-2007, 09:36 PM   #1
Full-timer
nickglase's Avatar
1988 34.5' Airstream 345
new york , New York
Question replacement keys for main door lock (have number)
Hi All,
Since buying my MH 4 years back, I've been living without a main door key. (Surely have had to climb through the windows a few times when it was locked by accident). I was just fishing through some dealer info in my owners manual and I found a Keeler "main door key #TR096." Anyone know a locksmith or supplier who might be able to do something with that number?
From what I understand replacing the cylinder is a bit of work.
Thanks much,
Nick
Urban camping in San Francisco, Ca
1988 Airstream 345 Motorhome
1964 Vespa GS
1982 VW Qauntum, turbo diesel
1979 Triumph Spitfire 1500
nickglase is offline   Reply With Quote
Old 03-29-2007, 09:59 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I'd ask a good locksmith, they would know if that would allow you to make a key. In the winter of 2005 I ended up having a locksmith pick my deadbolt and make a key. He did this with about an hour of trial and error and without removing the lock. I took the MH to his shop and he ran back and forth trying keys until he had it. I think he was figuring out the key one cylinder at a time.
It would be good to solve this problem since the latches built into the door are prone to catastrophic failure.
Here's the story of my adventures with this issue:http://www.airforums.com/forum...oes-19738.html
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 03-29-2007, 10:14 PM   #3
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Easy, Take the number to a half decent locksmith and he can make you a key.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 03-30-2007, 01:24 PM   #4
livexl's Avatar
1992 35' Airstream 350
Huntington Beach , California
email me your address and I'll send you two keys a friend made going by the number ...
livexl is offline   Reply With Quote
Old 04-10-2007, 08:50 PM   #5
Full-timer
nickglase's Avatar
new york , New York
magic keys
livexl
Thanks a million, those keys worked perfectly. Saved me a ton of work & having to deal with locksmiths who didn't have much clue what kind of lock I had.
Many many thanks,
Nick
1964 Vespa GS
Old 04-11-2007, 07:58 AM   #6
livexl's Avatar
I'm glad the keys worked out for you Nick. I've gotten lots of help from this board, its good to do a little payback. Thanks for the update, Dan
Old 06-13-2017, 09:46 PM   #7
1987 32' Excella
Zwolle , Louisiana
We recently bought a 1987 A/S Excella. There was no key for the door. I have read some of the posts on here and they mention a number. Where is the number located? We found PKE. Thanks!
Kakb is offline   Reply With Quote
Old 06-21-2017, 09:12 PM   #8
1987 32' Excella
Zwolle , Louisiana
Trimark Corp.
Old 06-22-2017, 04:50 AM   #9
Virtually all the parts for a Keeler latch assembly are no longer available, the key cylinder being one of them. I believe your best bet would be to remove the latch assembly from door which is not really that hard. There are two screws on the edge of the door and 3 screws holding the inside plate to the latch assembly. Remove those 5 screws and the latch assembly can be removed. Take it to a good locksmith and he should be able to make you a key.
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Airstream keys Pahaska Our Community 15 06-16-2005 09:03 PM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 08:18 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
