Old 06-09-2009, 02:19 PM   #1
1982 28' Airstream 280
Venice , California
Replace 12v Fuse Box with Breakers?
Looks like it's time to replace my fuse box. There are a number of shorts and loose connections. I'm wondering if there is a drop in replacement that uses breakers instead of old style fuses. Has anyone done that conversion?
dalefox is offline   Reply With Quote
Old 06-09-2009, 03:22 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I have not used them before, so I can't tell you if they work or not. Here you go. Glass Fuse Type - Snap in Mounting- Non-Cycling - Modified Reset
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 06-09-2009, 03:43 PM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
Breaker boxes are expensive. Blue Seas and other make very nice ones. Try a marine supplier. For price comparison check out defender.com in Ct.
Over59 is offline   Reply With Quote
Old 06-09-2009, 03:57 PM   #4
Venice , California
Wow. Fascinating solution, Silverleeper. Those clip in breakers that actually replace glass fuses. I'll definitely keep that link on hand for another application. Sadly, in this case, the box has to be replaced because many of the terminals are loose or shorting. Wouldn't do any good to clip nice breakers into a bad box!
And thanks for the link, Over59. I'll take a look there. If I fall back and just replace this fuse box with an identical one, where would I likely find that?
Best,
/dalefox
Old 06-09-2009, 04:07 PM   #5
1967 24' Tradewind
Bellevue , Washington
I found a really nice fuse box at West marine products. Built for the vibrations in the moving Earthquake that is my trailer. Had a design that makes it easy to pop out the fuses and a cover to keep stray stuff from interferring.
DonMiller is offline   Reply With Quote
Old 06-10-2009, 06:55 AM   #6
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
If the box weren't shot you could use the little square automatic-reset thermal circuit breakers they put in trucks. Maybe you could find a nonconductive sheet material and fabricate a replacement. It'd save some bucks anyway. Keep us posted - and include pics. We love seeing how it should be done.
Jamie
jking is offline   Reply With Quote
Old 06-10-2009, 09:28 AM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
Check out BestConverter - Converters, Inverters, Electrical Supplies, Electronics for some ideas...they have lots of neat stuff to cure your electrical problems...
I got a new 3-way, converter/charger from them, but was able to keep my old fuse box by modifying it slightly - and - I bought some of those 'circuit breaker' type fuse replacements, and they work great!
Ray & Pat; Morada, CA
Old 06-10-2009, 09:39 AM   #8
Venice , California
Thanks. Speaking of converters, I have to replace mine now and was wondering if any of them (at an affordable price) also integrate an inverter. Any particular models I should look at?
Old 06-10-2009, 10:44 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
How about something like these
TYCO ELECTRONICS / POTTER & BRUMFIELD|W23-X1A1G-10|Thermal Circuit-Breaker | Newark.com
12v
Fuse Box TShepherd Electrical - Systems, Generators, Batteries & Solar 2 01-27-2008 04:53 PM
12 volt fuse box matilda Electrical - Systems, Generators, Batteries & Solar 2 06-27-2006 09:00 AM
Fuse Box?? dye904 Electrical - Systems, Generators, Batteries & Solar 4 10-27-2005 12:48 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
