Old 01-09-2011, 05:37 PM   #29
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Originally Posted by Keyair
To clarify..
The Aux heater under the rear third of the sofa has a pull knob under the sofa(see my first pic right side of pic). This controls flow of coolant from the engine to the heater core. The dash switch then controls the fan speed. The heated air comes out of the vent in the toe board under the rear edge of the sofa!
The water heater function is actually in the water heater...
Did I get this right now???
Got it! Thank you.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-09-2011, 05:39 PM   #30
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Ok, back to the AUX heater...
The replacement valve arrived today!
Got it off Ebay, for under $18 shipped.
Its identical to the original... and you can see how bad shape it was... siezed solid!
Is that the part the hooks to the pull cable to allow the coolant flow?
Athens GA
Old 01-09-2011, 11:00 PM   #31
Yes, the cable has a loop on the end, and that pulls on the pin you can see sticking up/out.
More photos coming...
Old 01-20-2011, 11:42 AM   #32
I did a pressure test on the heater core.... its not leaking!
I am thinking to clean it up, back flush reuse it now!
Old 02-12-2011, 12:06 PM   #33
I spent some time pressure flushing the core with the hose, back and forth untill it ran clear, then I filled it with some radiator flush solution and left it for a few days.
More junk came out, so another power flush and it seems to be clean inside now.
I retested the pressure, just in case.
Here is my pressure test rig!
Two Short lengths of 3/8" hose, 4 hose clips, one old tire valve, and one bolt with a round caphead, that was about 3/8" dia.
Looks like this assembled...
I know that the radiator system cap can be 12 or 16psi, and my Craftsman coolant pressure test kit says 25psi is the maximum safe pressure, so thats what I tested it too.
I pressurized the tire valve to 25psi via my tire inflator, from my compressor.
I tried it in a bucket of water... but there is so much air trapped in the core vanes, it was still releasing bubbles forever after!
In the end, I left it out of water for a couple of hours, and then rechecked the pressure, and it was within 1psi, which allowing for the small volume of air and the slight loss every time you attach and detach the inflator.
I think I will call it good!
Time to reassembel the unit!
Old 02-13-2011, 01:37 PM   #34
Kenneth
1987_345's Avatar
Waxahachie , Texas
Keyair,
I didnt read through the whole thread, but just asking...were you not able to find a new replacement? I'd hate to see that old one fail and flood your interior with fluid..
1987_345 is offline   Reply With Quote
Old 02-13-2011, 01:42 PM   #35
Hi,
Yes, I found several that fitted, but I am fairly comfortable that its ok, based on the pressure test.
Old 02-16-2011, 07:06 PM   #36
So almost a week later, I go to take off the "test fittings, and I get a loud powerful hiss!
I guess it really is holding the air pressure!
Today, I treated the surface rust on the main body and gave it a coat of paint!
Old 02-21-2011, 07:40 PM   #37
Here is the final assembly.
I could not get the Manufacturers sticker off, so masked around it.
Decided to do the motor bracket, and grilles silver for fun!
Motor assembled and fan in place with the clip.
I added foam sealing tape all around to seal the air path and prevent the core moving around, and reassembled.
Core securing brackets in place.
Done!
Still have to give the screws a dust of paint before I tighten them, and add the wiring grommet.
Old 02-25-2011, 05:16 AM   #38
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
Talking
Looks great. Now you should get another 25 years of service from the heater
Robfike is offline   Reply With Quote
Old 02-26-2011, 09:35 AM   #39
Lets hope Rob!
I am still puzzled by the taped off vent here...
Should it be like this?
Anyone?
Old 03-28-2011, 11:25 AM   #40
I removed my couch to get the bottom cushions re-stuffed today, while it was out I took the opportunity to replace the heater control valve and remembered this thread. Anyhow, here is a picture of mine, as you can see mine is covered with a sheet of metal that appears to be factory so I am guessing yours came blocked off as well...
8rmesse is offline   Reply With Quote
Old 03-28-2011, 03:58 PM   #41
Awesome!
I will make an aluminium plate then.... tape just does not do it for me!
Old 03-28-2011, 06:31 PM   #42
Agreed, mine appears to be covered by a scrap of the factory vinyl clad interior aluminum. At least the duct tape was used on a duct... Something it is rarely used on, although I still don't think you are supposed to cover large vent holes with it. Glad I was able to help you out a little bit.
What type of water heater do I need? doglickfarms Water Heaters, Filters & Pumps 12 03-28-2011 10:36 AM
Airstream water heater door LKSD Water Heaters, Filters & Pumps 9 03-23-2011 04:46 AM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 07:27 PM
Basic h/w heater question (empty tank) TennisMan Water Heaters, Filters & Pumps 4 03-01-2011 02:19 PM
