Old 01-03-2011, 03:15 PM   #15
Answered my own question!
Its called the "Motoraid" feature and is on the...
Suburban SW10DEM
Old 01-03-2011, 06:03 PM   #16
Robfike's Avatar
1986 34.5' Airstream 345
Speedway , Indiana
You have it. It's amazing how hot the water in the water heater gets from just that short piece of aluminum tubing welded to the tank!
The unit I installed can work on propane, 110Vac, and then the engine coolant. I did not hook up the 110Vac, since my original did not have that.
Robfike is offline   Reply With Quote
Old 01-03-2011, 06:38 PM   #17
It is only welded to the tank?
I assumed it went into the tank and went thru the hot water....
My water heater was replaced right before I got my 345, so I am pretty certain its just the LPG unit. I love the idea that the hot water is ready after a drive!
I am thinking I will have to build a seperate tank for this!
Old 01-03-2011, 07:28 PM   #18
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens , Georgia
Ok on my 87 345 I have a switch on the dash for aux heat. What does that do? Under sofa I see the heater I now know from this post it heats the hot water. I will check it out if mine is still hooked up. There is also a cable under there to open and close or turn off. Is that for the heat or for the hot water. Sorry if this is a silly question, but I just got the 345 few months ago. Thanks for any answers.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 01-03-2011, 07:44 PM   #19
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
the cable and pull knob is for the coach heating unit to receive hot fluid. Pull to actuate the heater. You can control the fan on the dash. Aux. heat High or low. off mode
John H. is offline   Reply With Quote
Old 01-03-2011, 07:56 PM   #20
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Is that aux heat for the people down by the sofa? And did I understand right if working properly it will heat the hot water?
Athens GA
Old 01-03-2011, 09:53 PM   #21
To clarify..
The Aux heater under the rear third of the sofa has a pull knob under the sofa(see my first pic right side of pic). This controls flow of coolant from the engine to the heater core. The dash switch then controls the fan speed. The heated air comes out of the vent in the toe board under the rear edge of the sofa!
The water heater function is actually in the water heater...
Did I get this right now???
Old 01-04-2011, 09:17 PM   #22
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Hot water
I've always wondered about the "AUX-HEAT" switch that was on my dash; couldn't figure out what it was supposed to do; but it turns out that my coach never came equipped with the "AUX" heater core/unit in the first place, just the switch. So thanks for clearing up that question.
Regarding hot water production, can anyone recommend a unit that uses propane, as well as circulated engine coolant to heat water? My rig came to me with only an electric heater, and no generator. I hate to think that I need a hook-up just to get a hot shower. THANKS.
streamquest is offline   Reply With Quote
Old 01-04-2011, 11:00 PM   #23
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Hot Water
6 Gallon Water Heater w motoraid & DSI
Most now are propane and ac electric for shore power use.
What is nice about the Motoraid, (FREE HOT WATER) is you can get on the road early and have the shower at the coffee stop on the way. When you resume the trip the air circulation helps get rid of the moisture on those dull days.
Dave
Old 01-04-2011, 11:47 PM   #24
masseyfarm's Avatar
Images: 56
[QUOTE=masseyfarm;933936]
6 or 10 Gallon Water Heater w motoraid & DSI
SW10DEM
Features:
  • 10 Gallon Tank
  • Combination 3-way Gas Pilot Ignition/Electric/Motor Aid
  • Electronic Ignition
  • Propane Gas Fired
  • 12,000 BTUH Input
  • 10.2 Gallon Per Hour Recovery (Gas)
  • 6 Gallon Per Hour Recovery (Electric)
  • Uses Flush-Mount Exterior Door
  • 16 7/32'' H x 16 7/32'' W x 20 1/2'' D
  • Made in USA
10 Gallon 3way Gas-Electric-Motor Aid with Electronic Ignition
Old 01-05-2011, 09:19 AM   #25
Atwood make a water heater with the coolant feature too...
http://www.atwoodmobile.com/images/waterheater.pdf
Old 01-05-2011, 10:07 PM   #26
1936 20' Clipper
1947 22' Liner
Curtis Wright
Many thanks for that info,
Charly
Old 01-05-2011, 10:09 PM   #27
Suburban SW6DEM Gas Electric Water Heater with Motor RV - eBay (item 320635597450 end time Jan-26-11 15:07:40 PST)
Old 01-09-2011, 03:49 PM   #28
Ok, back to the AUX heater...
The replacement valve arrived today!
Got it off Ebay, for under $18 shipped.
Its identical to the original... and you can see how bad shape it was... siezed solid!
What type of water heater do I need? doglickfarms Water Heaters, Filters & Pumps 12 03-28-2011 10:36 AM
Airstream water heater door LKSD Water Heaters, Filters & Pumps 9 03-23-2011 04:46 AM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 07:27 PM
Basic h/w heater question (empty tank) TennisMan Water Heaters, Filters & Pumps 4 03-01-2011 02:19 PM
