Old 09-19-2011, 10:15 PM   #15
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Thanks for the links. Yes, has to be a 'cheaper' way, but if the cheaper model is only going to last 12 months......
Old 09-20-2011, 07:48 AM   #16
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
How did it work?
I am very interested in Livexl setup as I have a 91 350 LE that has a non-functioning camera. Which camera did you choose from rearviewsystems and did you replace your monitor as well? I see how you wired it and I wonder if you get any interference or noise from the coaches original wiring? If it all worked well for you I may do exactly as you. Thanks for your input. Steve G
t7389sg is offline   Reply With Quote
Old 09-20-2011, 07:55 AM   #17
holden beach , North Carolina
Send a message via MSN to Tom-Mc
I have
I have a good camera as it was mounted inside.My monitor comes and goes as it heat up. If these park will work for you then PM me.
Tom-Mc is offline   Reply With Quote
Old 09-20-2011, 08:03 AM   #18
livexl's Avatar
1992 35' Airstream 350
Huntington Beach , California
I'm sorry I can't find the info on the camera but I'm sure if you tell them your situation they'll be able to help you. I did not replace the monitor. I am not experiencing any interference or noise from the coaches original wiring.
livexl is offline   Reply With Quote
Old 09-20-2011, 09:46 AM   #19
Silverton , Colorado
One of the nice things about the Intec is the markers showing how close you are to those immovable objects...does anyone in the US(southwest) work on the original systems? m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 10-23-2011, 09:42 PM   #20
crazeevw's Avatar
Was at AutoZone today, saw this setup. Realize that the screen is ultra small, but for the price???
Peak/Wireless back-up camera system with 2.4 in. LCD monitor (PKC0RA-01) | Back-Up Camera System | AutoZone.com
Name:	wireless backup cam.jpg
Old 10-23-2011, 10:03 PM   #21
1969 27' Overlander
Albuquerque , New Mexico
Good low cost CCTV camera.
I use a camera from Harbor Freight on my camper. I'll be installing one on my AS soon.
It's around $40.00, good resolution, has weatherproof housing with mic, runs on 12 vdc, and has AV connection with 50 foot cord.
It also has "night illumination" L.E.D.'s. for after dark.
You'll have to make a splice for the connection between the TV and trailer, and you'll need your own monitor. Any small television/monitor will work if it has AV input (Yellow RCA plug).
It's 4 conductor, so you can use a weatherproof phone jack, or you can use the 12 volts off the trailer battery as long as you have the ground connection between the TV and trailer. Really simple hookup. (12 volts positive, negative ground, video, audio.) If you have a "spare" pin on your trailer plug, you can feed just the video through it.
Cheap, effective, and lasts. I've had one on the front of my house for 5 years.
edglenn is offline   Reply With Quote
Old 10-23-2011, 10:09 PM   #22
1982 28' Airstream 280
Redwood City , California
I actually bought the same unit about a month ago. I intend on using it on the MH, but I installed it on my 20 foot enclosed ATV trailer for my trip to the sand dunes in Oregon. It worked out better then I expected. I actually wired the camera to work full time and not just in reverse. I think it was a great safety addition. I could see cars and 18 wheelers coming up behind me. It is wide angle so cars are closer to you then they seem in the camera. It was great for passing cars and trucks and knowing when I could safety pull back I to the right lane. It was probably at its max range for the wireless monitor and the signal would go out every once in a while, but the benefits certainly out weighted this disadvantage. In assuming it should work better in the MH with the transmitter and receiver located in the same vehicle. It was one of those impulse buys at the cash register, but I am very happy I did and you can't beat the price.
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-23-2011, 10:37 PM   #23
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
From most of the digging that I've done on this subject, the Voyager brand seems to be the class of the field. My moho came with nothing in the way of cameras or monitors, but here's the one I'll be using. This is the housing only, that is available for left, right or roof center mounting. I like the streamlined shape that's available in chrome finish to match the polished aluminum.
Charly.
streamquest is offline   Reply With Quote
Old 10-25-2011, 10:25 AM   #24
1969 27' Overlander
Camera & Monitor
Here's a $35.00 camera, and $25.00 dual input monitor I'll be using in my AS and TV.
Old 10-25-2011, 05:55 PM   #25
crazeevw's Avatar
edglen, please tell us where you found this setup! Looks good, and jeez, what a great price! Thanks, Derek
Old 10-26-2011, 10:16 AM   #26
1969 27' Overlander
The CCTV camera I get from Harbor Freight.
I've used several on my house for security (connects right to the aux input of the television) and the resolution is very good. It's lasted for 5 years with no problem. The audio is good, too. You have to use a dab of silicone where the cable enters the housing (which is sealed and gasketed), the grommet isn't sufficient to prevent fogging. It runs on 12 volts DC, one power, one negative, one audio, and one video. The factory uses a 4 conductor phone cable, which works fine. I modified mine to plug into a standard phone jack for ease of installation, since the distance was further than the supplied 50' cable.
I installed one one my 1970 Mowhawk Honorbuilt trailer, and it works fine.
These cameras are far better than the old junky ones they used to sell.
The 3.5" LCD monitor I ordered on EBAY (Part #220871253052) from Hong Kong. $25 and free delivery. Sorry, but I can't even get an Amercian company to return my phone calls for less than $25. Too bad, really.
The LCD displays usually last only a year or two, but for $25, I can afford that every couple years. It plugs right into the cigarette lighter. You'll have to do a little wiring and routing to get the wires from the trailer to the cab of the TV, but that isn't too hard.
I plan on using a toggle switch to select the video feed (One camera will be pointed directly down to the tow-ball/hitch, so I can hook up solo, the other camera will be on the trailer, mounted above the bathroom window.) I can route the wires through the vanity cabinet, along the inside of the trailer, to the front connector.
I'll be posting pics pretty soon of the "Aerojava" trailer. It's almost ready.
Old 10-26-2011, 07:32 PM   #27
crazeevw's Avatar
Edglenn, was at Harbor Freight this past Sunday, guess another trip is in order! Thanks for the tips on where to purchase. Thanks, Derek
Old 10-26-2011, 08:59 PM   #28
1969 27' Overlander
You're welcome!
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Parts needed - 345 Spare Tire Cover on rear, et.al. audiv8q Exterior Restoration Forum 0 02-24-2011 02:33 PM
