Old 02-05-2012, 11:41 AM   #1
Rear Airbags for a 1984 345... need part #'s.
Spent several hours looking thru the forums here and elsewhere looking for the part Number for the rear aibags, on my 1984 345.
I came up with this one, but am a little confused between model years and lengths...
W01-358-5412
or..
<LI class=alt>Firestone Bellows Number:1T14C-3 or 1T14F-4American Carrier Number:8003-011
<LI class=alt>Holland (Neway) Number:900-57-057
Can ayone confirm?
Old 02-05-2012, 01:00 PM   #2
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Wish I could help Steve, believe somewhere I've read the actual part number is stamped on the bottom of the airbag? If I can find anything, I'll be sure to post.
Derek
Old 02-05-2012, 01:11 PM   #3
Found this that helped me a bit...
Guess I have to crawl under there sometime soon..
Firestone Air Spring Identification Tips, Airide Air Bag Identification Tips - TruckSpring.com
Old 02-05-2012, 01:16 PM   #4
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
W01-358-5412
or..
Can ayone confirm?
Those numbers look like the correct ones. Check here to be sure. Firestone Air Spring Identification Tips, Airide Air Bag Identification Tips - TruckSpring.com
These guys have everything you need.
Cheers, Dan
Old 02-05-2012, 02:47 PM   #5
Thanks Dan.
Just trying to compile a list of parts I need, and could not be sure based on what I was reading...
We really need to get some of these things all compiled in one place, so its easier to find!
Old 02-05-2012, 02:55 PM   #6
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Your air bags may be different from mine
Thanks Dan.
My air bags are self contained with no external tank.....are yours? I am having a time getting part numbers from the shop but will try if you think yours might be the same.....Ron research mine...I can check tomorrow...p
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 02-05-2012, 03:22 PM   #7
crazeevw's Avatar
Front Air Bags on my 345 are on separate air valves. Rear bags are connected to a tank, with a 12V pump under the bed in mine.
Steve, maybe a 'sticky' thread with parts numbers. Know Dean (dadstoy) would sure appreciate it if someone could help him with radiator hose parts #'s.
Derek
Old 02-05-2012, 03:24 PM   #8
Paula, from what I see and know, the 345's system is very different, with a Compressor, Tank, and load leveling valves. The system is designed to keep the weight balanced between the drive and Tag axle.
Old 02-05-2012, 03:29 PM   #9
SteSpot's Avatar
1968 28' Ambassador
I am working on getting that part number
Derek
I am trying to get that part number for Dean......getting that shop to pay attention is a challenge.....maybe before they get another check might work. p
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 02-05-2012, 03:49 PM   #10
Gypsy Jo's Avatar
1977 28' Argosy 28
Bullhead City , Arizona
Let the boxer loose on them!
Jo
Gypsy Jo
1977 Argosy 28' Motor Home
Gypsy Jo is offline   Reply With Quote
Old 02-05-2012, 04:07 PM   #11
SteSpot's Avatar
1968 28' Ambassador
Actually Bandit lunged at one of the workers.
Bandit was inside the MH with us and a worker came to the door--Bandit appeared to not be pleased....yikes...I don't think he would bite but since he is a rescue dog I don't know what his past was about and every once in awhile, he lunges at someone.....usually a worker with a cap and dark clothing....of course the guy put his face right in front of Bandit....perhaps Bandit felt threatened.....he also lunged at someone at the salvage yard.....I am always on alert....he is unpredictable....on the other hand, he thinks he is a lap dog and it is possible he just wants to play.....I just can't afford to find out........p
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 02-05-2012, 07:30 PM   #12
Air bag systems are pretty simple but Airstream did make a few changes over the years. Post a couple of pics of your system and it should be easy to identify.
Cheers, Dan
Old 02-05-2012, 07:40 PM   #13
Here they are...
You can see they are way past being good, but they are working...
Drivers side;
Pass side;
Old 02-05-2012, 08:44 PM   #14
Here they are...
Drivers side;
Pass side;
That is the basic American Carrier System set up as on my 280. I'm not sure how it is set up to tie in with your tag axle. There is a video floating around here somewhere from Airstream sales showing how the coach can climb a curb allowing the suspension to flex enough to keep both axles/tires on the ground at all times.
From the picture your ride height is way too high. There are two dimensions given, one is 8 3/4" top of bottom crossmember to bottom of upper crossmember. The other is 10 3/4" I think. There was a change somewhere around '82/83'. The rubber of the bags should be down over the lower aluminum cone and the "dog bone" cross link in the first picture should be nearly horizontal rather than at the angle in the picture. This may be because you are up on on your leveling jacks. Remember also if you get too high that the wheels lose traction you also lose your parking brake. Use some good wheel chocks.
If you need to you can adjust the ride height at the leveling valve, the arm can be adjusted on the valve itself or if you want to take the easy way out, you can bend the link that connects the valve to the lower crossmember.
Cheers, Dan
Rear airbags on '87 345 - any tips or tricks moeriv Classic Motorhomes 6 11-15-2011 08:31 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
LED Lights on 87 345 rear tail/turn Myrtle lynn Classic Motorhomes 19 02-28-2011 09:43 PM
Parts needed - 345 Spare Tire Cover on rear, et.al. audiv8q Exterior Restoration Forum 0 02-24-2011 02:33 PM
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
