Any help to source a new air tank? Found leak under strap support hole in tank will not fill air bags had slow leak now compressor runs constantly thanks Jonathan
I would be surprised if there is a direct replacement for your tank avialable. However there are lots of places that sell air tanks for trucks and rv's.
You might try looking at Truck Springs. They sell suspension components and in the link provided they list various air tanks.
Good luck!
1975 24' Argosy Motor Home
Hillsburgh
, Ontario
I found a couple of 5 gallon aluminum air suspension tanks, both from different sellers; just picked the cheapest ones. Plugged the holes I didn't want, cut off mounting brackets and re-welded to other side so drain was pointing down. Aluminum won't rust.
Cheers
Tony
