Old 01-27-2010, 04:53 PM   #15
1984 31' Airstream310
College Station , Texas
Good evening:
Getting back to this aspect of my MH project! My air compressor seems to work fine. The air bags fill up right on que and then will take more than one day to deflate. No obvious rapid leak. Overall, the ride relating to the rear end is pretty stiff. Does not feel like much cushioning is happening. The shocks are new. Any suggestions?
PD
pdallas is offline   Reply With Quote
Old 01-27-2010, 05:07 PM   #16
Originally Posted by pdallas View Post
Good evening:
PD
There is an obvious leak.
When the little "check valve" that's in the air pressure line starts going bad, it does not shut off the return to the compressor.
That allows the air from the bags to flow back thru that valve and back into the compressor.
When that valve is working correctly, it only aloows air to flow to the bags, and not from them.
I would suggest that you replace that check valve as soon as you can.
Old 04-15-2010, 05:02 AM   #17
Finally got this finished and it works very well, I have complete control over the whole system and I'm very pleased with the results
moonshine is offline   Reply With Quote
Old 04-12-2012, 07:08 AM   #18
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
Do you stock the check valve?
elbundi is offline   Reply With Quote
Old 04-12-2012, 11:16 AM   #19
Yes we do.
Old 04-14-2012, 11:14 AM   #20
MaryContrary's Avatar
on the road , CA and OR this summer!
Images: 41
anyone out there replaced their compressor? and if so, with what brand or model?
my tank, electrical and lines are good,but compressor is weak and needs to be upgraded
1984 310 Limited Motorhome
my AS Moho blog
for the love of all vehicles round and shiny
MaryContrary is offline   Reply With Quote
Old 04-14-2012, 12:03 PM   #21
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I use one of these VIAIR Corporation - 450C IG Part No. 45050 45058
I like the 100% duty cycle at 100psi. It might be a bit of overkill but I don't worry about air pressure any more.
Cheers, Dan
Old 04-14-2012, 02:00 PM   #22
Airstream used 2 different compressors.
Which one do you have?
Rear air bag question porourke General Motorhome Topics 7 10-09-2011 10:45 AM
air bag leveling system jagcb750 Classic Motorhomes 58 04-27-2008 03:48 PM
Rear air bag modification? bencbailey Airstream Motorhome Forums 9 08-06-2005 09:31 AM
rear suspension air bag inflation tovedude Mechanics Corner - Engines, Transmission & More... 3 11-30-2004 06:50 PM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
