Old 02-26-2015, 04:58 PM   #15
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
axles????
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 02-26-2015, 07:04 PM   #16
1994 34' Excella
Warren , Manitoba
I would replace the steering damper, or if the unit doesn't have one, I would install one. Way back in 1976 I bought a brand new Dodge Ramcharger4X4 fully loaded. After a month it developed a shake and I took it back to the dealer. In less than a year Chrysler bought the truck back. They tried new tires and rims, new axles,wheel bearings, hubs, U-joints, new drive shaft, new transfer case, new transmission, new motor mounts, and everything else possible. Nothing helped!! In 200 miles it would shake 2 or 3 wheel nuts loose. They finally admitted they had no idea. Good luck finding the problem, but try the simple first. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-27-2015, 06:11 AM   #17
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Originally Posted by FishinHatteras View Post
5 bucks says it's an imbalanced wheel.
You have more than likely lost a wheel weight. Most wheel weights these days use glue as opposed to the traditional ones that are "clamped" to the edge of your rim. In cold weather, that glue loses its "sticking" power, and can get thrown from the rim.
I am sure this is right, will only add sometimes you get separation in the tire and it as to be replaced, first try balancing.
larryglarson is offline   Reply With Quote
Shaking my fist at the gods of camping andreasduess Airstream Lifestyle 14 09-22-2013 08:11 PM
Shaking up Bambi tetstream 2005 and newer - Bambi all models 5 01-06-2008 10:49 AM
A ghost in the rose garden... enduroryda Off Topic Forum 7 08-04-2006 06:33 PM
Globetrotter has "Canada" in ghost letters.... leefields Off Topic Forum 2 07-26-2006 02:22 PM
Creeking/Shaking only in backing sovereignrwe Axles 6 07-26-2004 12:34 PM
